Old 03-28-2022, 03:33 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Softening rock hard rubber
I've watched all of the U-Tube videos and read/heard all of the sales pitches of various products and am understandably thoroughly confused, which at my age ain't unusual. What have YOU used and with what short/long term results?
Old 03-28-2022, 04:02 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Softening rock hard rubber
Counselor....Sometimes, you have to be ready to accept the fact that you just CAN'T make chicken salad out of chicken dookie! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-29-2022, 07:58 AM   #3
jayvee34
jayvee34's Avatar
Best analogy yet. LOL
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 03-29-2022, 12:41 PM   #4
oldford2
oldford2's Avatar
Just the reverse:
If you have something soft, how do you get it hard.
John
oldford2 is offline   Reply With Quote
Old 03-28-2022, 04:07 PM   #5
Lawson Cox
Lawson Cox's Avatar
My Daddy always told me "Can't never did anything". He was a wise man. (Picture a laughing emoji here)
Old 03-28-2022, 06:10 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Picture a frowning guy who CAN'T post pictures, here.
DD
T5 W/TORQUE TUBE
Old 03-30-2022, 09:30 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
DD
Or picture a guy with a soft noodle in one hand and a piece of hard rubber in the other hand, who still can't post a picture
John
Old 03-30-2022, 05:20 PM   #8
Rich-CO
Try soaking in Dot 3 brake fluid for a couple weeks.
Rich-CO is offline   Reply With Quote
Old 03-30-2022, 07:22 PM   #9
ford38v8
ford38v8's Avatar
If it doesn’t liquify that soft noodle, it might be ok for rubber. You try it first.
Alan
ford38v8 is online now   Reply With Quote
Old 03-30-2022, 07:37 PM   #10
GB SISSON
GB SISSON's Avatar
I am replacing the water pump in my 50 year old tractor and both hoses have been soaked for years by a leaking power steering pump. Both hose are in excellent condition and are so soft and pliable I wondered if they were replacement silicone hoses, but PO says no way. So, how about soaking in PS fluid? And as for the soft and hard discussion I knew it was only a matter of time for you boys~!......
GB SISSON is online now   Reply With Quote
Old 03-30-2022, 08:02 PM   #11
ford38v8
ford38v8's Avatar
Originally Posted by GB SISSON View Post
…….. And as for the soft and hard discussion I knew it was only a matter of time for you boys~!......
And you knew this how? 🥸
Alan
Old 03-30-2022, 08:22 PM   #12
Lawson Cox
Lawson Cox's Avatar
I have thought about that. Still considering it. I found a good length of old hardened rubber garden hose I'm gonna experiment with.
Old 03-28-2022, 04:13 PM   #13
Kube
Super Moderator
Kube's Avatar
Soaking in automatic transmission fluid works occasionally.
Old 03-28-2022, 04:30 PM   #14
51 MERC-CT
51 MERC-CT's Avatar
Back in the time when we used to use gasoline as a lubricant to sand lacquer
color coats prior to buffing and polishing, rubber squeegees were used as part of the process.
If you left a squeegee in a bucket of gas overnight, the next day the squeegee was like a limp noodle.
Old 03-28-2022, 04:38 PM   #15
Lawson Cox
Lawson Cox's Avatar
Do you recall if the squeegee returned to "normal" after it "dried out"? I'll have to give that a shot. I've got to drain the tank on Apatchy anyhow, so I'll give it a shot.
Old 03-28-2022, 05:56 PM   #16
51 MERC-CT
51 MERC-CT's Avatar
The squeegees were, after soaking, rendered useless for the purpose but
as I recall remained softer than they originally were.
Old 03-28-2022, 08:17 PM   #17
Lawson Cox
Lawson Cox's Avatar
I have just been trying to follow your lengthy dissertation to me about posting pictures, DD. 'Nuff said.
Old 03-28-2022, 08:47 PM   #18
ford38v8
ford38v8's Avatar
It must be remembered that any and all of the products mentioned in this thread are solvents, and as such, will break down the composition of rubber as manufactured. In that less than stable condition, rubber becomes soft and gummy. Some solvents are better than others for use with rubber. The rubber industry uses toluene, which freshens up cured rubber that is to be rebonded, such as tires with recaps. If to be bonded, heat and pressure is used. If used only to freshen the surface, the end result will initially appear and feel as new, but is in fact a degradation of the original surface.
Alan
Old 03-28-2022, 09:16 PM   #19
petehoovie
petehoovie's Avatar
Some good tips here > https://homeguides.sfgate.com/chemic...-13414995.html
Old 03-28-2022, 10:07 PM   #20
Pete
What Alan said in post #10.
Common bleach (sodium hypochlorite) works sometimes. We used to soak our qualifying tires for the midget in it before it was illegal.
