I know better to post this on Hamb but I spend more time here on the Barn. I have joint problems and finding its harder and harder to steer my 38 5 window. Anyone gone this way? Thanks Pete
I know of one example of electric assistance being applied to a Model A. It works well. Off topic but one of our dailys, a Fiat 500 has electric power steering.
Mart, you are a brave man to drive a car with Italian electrics , specially the steering, LOL
Lawrie |
I installed one on a '35 for one of my Hobby Members and it is one slick piece to drive.
Lawrie
He is already used to Lucas, what could be worse? Bruce
Works good Lasts long time |
Super Moderator
Lucas gets an undeservedly bad rap.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
I disagree. The Prince of Darkness was a well deserved title. My Sprite and my wife’s MGB had more Lucas issues than any other sort.
Alan |
Angledrive please tell us more about the 35 you installed electric power steering on!
I should think it would be very welcome in tight parking lots. |
Yes, more info!
Cheers, Jim&Sandy McGregor, IA |
I to would love to put it in my 34 p u
It's a pretty common mod in the vintage Mustang world and
becoming more popular daily.... Here's some of the details off the thread- The cars with "fail safe" electric power steering.... 2004-2009 Toyota Prius 2009-2013 Toyota Corolla 2006-2011 Toyota Yaris - (With ABS works in Fail-Safe). 2006-2011 Toyota Yaris - (Non-ABS needs VSS signal or flashing LED) 2007-2009 Nissan Versa 2009-2012 Nissan Cube 2012-2014 Kia Soul The hot ticket for the 65/66 Mustang, which has a similar 1-piece shaft from the steering wheel down to the steering box, like what I'm guessing you'd also have on a '38, is the Prius or Corolla setup. There is a packaging deal and I don't know what your '38 underdash space situation is..... I'll post a photo of what these items look like. It's basically a cut, and section deal with your factory steering shaft, plus some wiring. By "fail safe" I gather you've still got steering if the electrical power goes off..... you just don't have power assist. Last edited by 1948F-1Pickup; 03-02-2021 at 07:26 PM. |
#13 |
Have looked into the possibility a while back as what was offered from
'UNISTEER' The major obstacle that I found was if your vehicle had a column shift. If the vehicle has a floor shift the installation looks relatively simple. https://www.unisteer.com/collections...power-steering
#14 | |
#15 |
2018 Toyota Camry has electric steer.
#16 |
I know the Saturn unit is a popular unit. I have a friend putting on in a 38 PU. I put a GM 605 unit in my 47 PU, But had problem getting th e pump installed. Works now, but i'd use electric an my next project.
#17 |
I did a cylinder head replacement on a ‘35 Ford with an 8BA with a GM steering box and a pump mounted over the left cylinder head between the two center spark plugs and run by a belt off the rear of the generator.
Some old Chrysler cars had the P.S. pump on the back of the generator. I believe this car had one of those generators with a pulley added where a p.s. would go. It worked like it was meant to be there. |
#18 |
I can not find any unit that is 6 volts??? or I would buy one.....
#19 |
#20 |
