01-10-2020, 05:13 PM | #1 |
Two Piece Oil Pans? When were they made?
I have searched but cannot find any reference to the 2 piece oil pan. I am looking for a 2 piece oil pan, one that will let me remove the flywheel without dropping the oil pan. What year car or truck were these installed new?
01-10-2020, 05:36 PM | #2 |
Re: Two Piece Oil Pans? When were they made?
Don't ever remember seeing one but it wouldn't take much to strategically cut the bell housing portion off and create a bolt together joint to allow it to be removed.
01-10-2020, 05:46 PM | #3 |
I have no date when these were released but I believe it was for the 59 AB trucks with the larger clutch. I have a few on the shelf and can snap some photos if you want to see what they look like.
01-10-2020, 06:31 PM | #4 |
I agree with Stenny; jailbar trucks had them
01-10-2020, 06:42 PM | #5 |
Here's one 2 piece.
https://picclick.com/1946-1948-Ford-...718261268.html |
01-10-2020, 06:51 PM | #6 |
01-12-2020, 10:10 AM | #7 |
[QUOTE=V8COOPMAN;1840016]Here ya go! DD
DD - looks like I have the 1st 2 piece you picture with the "regular" size drain plug. I must say that that plug opening is large and when you open to drain - well its like the entire contents of the pan drops out like Niagara Falls! You need a healthy size drain pan to take all that flow at once! Last edited by PeterC; 01-17-2020 at 09:35 PM. |
01-12-2020, 11:17 AM | #8 | |
[QUOTE=PeterC;1840491]
Peter...You're a funny man! There is NOTHING "regular" about that little coupe of yours. That car is "special" from the north end to the south end, including everything in the middle. I thought I had studied every nut and bolt on that car, but never realized until now that it had a two piece pan. DD |
01-10-2020, 07:08 PM | #9 |
And there is two versions ; one has the regular big drain plug, the other has the big clean out removeable plate.
01-10-2020, 07:26 PM | #10 | |
Brian....Actually, there are at least three types. This one is supposedly Canadian heavy duty truck application. DD |
01-10-2020, 08:52 PM | #11 |
I have known about them and using them for years. They certainly do make life a lot easier when doing a clutch and flywheel job.
01-11-2020, 04:45 PM | #12 |
Does this mean a person doesn't have to remove engine to replace clutch plate ?
01-11-2020, 04:54 PM | #13 |
01-10-2020, 10:05 PM | #14 |
Coop, Thanks for the photos, that yellow one shows the big clean out removable plate I mentioned, what is the third type?
01-11-2020, 10:20 AM | #15 | |
Brian.... 1st with a normal, small drain plug. 2nd with large, steel ROUND clean-out hole. 3rd with this OBLONG style, steel clean-out-shaped plate cover like YELLOW above. DD |
01-10-2020, 10:44 PM | #16 |
What years were they made? Thanks everyone for the pictures and info.
01-10-2020, 10:54 PM | #17 |
Ford-ers;
Note the difference in the road draft arrangement -- a bolt on draft tube extending aside to rear of the engine rather than the slotted tri shape can --more Canadian &/or Export than USA -just My opinion More neat Ford stuff & practical! Love it Gene Tulsa Re picture in post # 8 Last edited by G32; 01-10-2020 at 10:57 PM. Reason: Mis quote |
01-10-2020, 11:25 PM | #18 |
The yellow pan is Canadian military. 1942-48 Part#6675. I have one of the military two piece pans and a regular two piece pan. Both oil bosses on them do not have a place for a oil return line. They do have one in the side of the pan. I believe that would make them 1942 and earlier.
01-11-2020, 02:06 AM | #19 |
Hi all; I restored a low miles '48 Canadian M-37 1/2 ton pickup and it came with a 2 piece pan. All the rest I have seen were on big trucks/COE's too. Newc
01-11-2020, 06:13 AM | #20 |
If anyone has just the pan for sale, I’d be interested. I have the back piece.
