Old 09-03-2015, 10:39 PM   #1
48fordconv
Default 48 Ford Conv. Right side mirror
I am looking for a mirror for right side of my 48 Ford Conv. Does anyone made a new one with the base as wide as side chrome ? Also any that will bolt to door that you can see from drivers side ? thanks
48fordconv is offline   Reply With Quote
Old 09-03-2015, 11:05 PM   #2
fordor41
fordor41's Avatar
Default Re: 48 Ford Conv. Right side mirror
never saw any style mirror on a 41-48, for the P.S., that you can see from the drivers seat. Even the D.S. usually vibrates so badly you can't see anything
fordor41 is offline   Reply With Quote
Old 09-04-2015, 06:26 AM   #3
Vic Piano
Vic Piano's Avatar
The OEM accessory cowl mirrors base on the '42-'48 Ford is slightly narrower than the stainless trim on the hood and door. I have them on my '47 Convertible and the passenger side mirror is not visible (usable) from the drivers position however, I've been told it is in an excellent position for a passenger applying lipstick...
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 09-04-2015, 09:19 AM   #4
JT FORD
JT FORD's Avatar
It was a problem for the '49-51's for pass. side for along time. Now the new mirrors will work on either side. They probably will look different on the '46 - 48's, but if you
drive these cars you really need mirrors on both sides!
JT FORD is offline   Reply With Quote
Old 09-04-2015, 11:04 AM   #5
bobH
Right-on, Vic. My passenger noted the same thing.
I addressed the 'right-hand-mirror-problem' by making a little bracket that clips on to the vent window. It has a small, store-bought, convex mirror on it. It slips on the edge of the vent window, around the upper hinge. I leave it on most of the time, and can easily remove it, for example at a car show.
A few of my 46-48 friends have noted this arrangement, and I have made a few (very few) duplicates, out of polished SS.
This still leaves the cowl mirror visible for my passenger.
bobH is offline   Reply With Quote
Old 09-04-2015, 11:14 AM   #6
woodiewagon46
The cowl mirrors for the PS side of the car, sold by several places are just about useless. It is physically impossible to see it from the drivers seat. Some of the hot rod guys use a "peep mirror" that clips to the top edge of the door but for a convertible that's a different issue. I also use the convex mirror that bobH uses but mine has adhesive on the back that I adhered to the upper part of the windshield on my '46.
woodiewagon46 is offline   Reply With Quote
Old 09-04-2015, 03:10 PM   #7
48 coupe
48 coupe's Avatar
I just posted some picts. of my 48 mirrors. Couldn't figure out how to put on here.
48 coupe is offline   Reply With Quote
Old 09-05-2015, 02:21 AM   #8
tiger.1000
Interestingly, I have just fitted one on the passenger's door of my 69 Charger, ensuring that within a gnats cock it was in the same position as the one on the driver's door.
Yes, utterly useless but looks pretty !
tiger.1000 is offline   Reply With Quote
Old 09-05-2015, 10:34 AM   #9
V12Bill
V12Bill's Avatar
Watched an episode of Jay Leno where he mounted a stick on mirror to the right side vent glass and then adjusted the vent glass to see out of the right side of his car.
V12Bill is offline   Reply With Quote
Old 09-05-2015, 01:57 PM   #10
Lanny
Lanny's Avatar
I removed my stock '40 cowl mirrors, and mounted them on my doors.
Here are some pictures I just took. I can see whats behind me pretty good.
Click on picture to Enlarge
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
