10-10-2023, 01:47 PM | #1 |
Info. regarding 1939 Mercury door glass
Anyone have any information on the door glass for a 39 Mercury 4 door sedan? Is the door glass the same as the 39 Ford, or is it in it's own category as well? I unfortunately do not have any good patterns for the doors so I can replace the glass.
10-10-2023, 02:13 PM | #2 |
Re: Info. regarding 1939 Mercury door glass
Mercury is different than Ford.
Try Sanders Reproduction Glass, 6295 NE 147th Ave, Vancouver, WA 98682 as they list glass for your car. If for some reason Sanders (or someone else) does not have patterns, I have a scroll of patterns that likely has the Mercury. However the scroll machine needs tlc to work and I have not got to that project yet. |
10-10-2023, 02:50 PM | #3 |
Sanders has the glass, but I can have it cut locally for cheaper than what they want for it. If I even had just a paper pattern that would help to get it cut. Hopefully someone will have clarification on the door glass between a 39 Mercury, and a 39 Ford.
10-10-2023, 03:11 PM | #4 |
I got a Merc 4 Door, not sure just how I would get you a good accurate pattern of the glass????
10-10-2023, 05:58 PM | #5 |
How much difference can there be? Pay the extra in price. We should be doing all we can to keep the ever-dwindling list of good, reliable vendors in business.
10-10-2023, 07:31 PM | #6 |
10-11-2023, 02:57 AM | #7 |
Comparison shots of the 1939 Ford Deluxe Fordor Sedan and 1939 Mercury Town Sedan. |
10-11-2023, 09:11 AM | #8 |
It would have been nice if they could have provided some measurements. I'm not seeing a whole lot of difference in the doors. I do know there is quite a difference in the front clip and rear fenders, and I also believe there is a difference in body width as well. Now when it comes to buying parts out of state vs. buying and supporting my local small business, I will support my local small business first before sending money to an out of state vender. In a lot of cases I do not have a choice, but here however I do have that choice to support my local small business.
10-11-2023, 09:17 AM | #9 | |
10-11-2023, 04:54 PM | #10 |
Close up view of the Windows showing differences between the 1939 Mercury and Ford |
10-11-2023, 05:27 PM | #11 |
When I had my 40 Merc 4 dr. sedan it had a cracked glass in the left rear.
I got a replacement glass from Ball's Rod and Custom. It fit perfect. Don't know about pricing, been several years ago. If your cracked glass is still in the car, remove and use for a pattern.
IN GOD WE TRUST - SEMPER FIDELIS John Last edited by jayvee34; 10-11-2023 at 05:33 PM. |
10-11-2023, 07:06 PM | #12 |
Once you have the fuzzy glass tracks in place; it's not too hard to make a pattern out of 1/4" masonite.
Once it gets close; I pin it to the glass channel to finalize the size and location so the cam on the regulator grabs the roller and makes the "smoker" vent operation function. |
10-11-2023, 08:43 PM | #13 | |
10-12-2023, 02:52 AM | #14 |
I used Sanders, excellent quality & people. Request the Ford Safety glass logo with your requested date; they' do it, and place it where YOU want it!
* My '33 3w had a cracked aftermarket windshield. (one single sheet, see it, lower passenger corner by sticker.) *Did you know that Ford Safety Glass= two glass sheets as one? (read the story on Henry deciding to make 'safety glass' for every car. Very interesting! view the glass edge(s) on your EFV8 Last edited by highbeams; 10-12-2023 at 02:55 AM. Reason: clarity. |
11-10-2023, 10:55 AM | #15 |
For some reason I couldn't post for a while, so I couldn't respond to anything. Does anyone have the book that covers the part numbers on the bodies of both Ford and Mercury for the glass in 39? Look at the photos they look the same to me. Unless someone was holding a measuring tape up on the window openings the contours and glare on the paint make any differences difficult to see.
11-10-2023, 02:39 PM | #16 | |
11-10-2023, 03:00 PM | #17 | |
11-11-2023, 12:07 PM | #18 |
I suspect that the 39-40 Mercury glass is different shape than the 39-40 Ford glass. The bodies of the Merc vs Ford are uniquely different. Why not call Sanders glass and ask them the difference. Bob Drake used to sell glass patterns. You might call them to see if they have them for a Mercury.
11-13-2023, 10:22 AM | #19 |
I did see that they sell some patterns for other models, but nothing for the 39 / 40 Mercury. I'll drop them a line to see if they have the patterns.
