01-18-2019, 08:58 PM | #1 |
1935 Ford 15-P
Saw this on another forum. Thought it was interesting.
Know nothing about it, nor was any supplied. Know there are some plane buffs here. Very nice craftsmanship. |
01-19-2019, 04:02 AM | #2 |
Re: 1935 Ford 15-P
I like it a lot. cool as anything.
Mart. |
01-19-2019, 05:33 AM | #3 |
Re: 1935 Ford 15-P
Very cool.
It would need one of Skip's coils before I'd go up in it. |
01-19-2019, 07:05 AM | #4 |
Re: 1935 Ford 15-P
I wonder why the heads were put on the other way?
01-19-2019, 07:10 AM | #5 |
Re: 1935 Ford 15-P
It,looks like,that they used some of the car gauges on the instrument panel.
01-21-2019, 12:02 PM | #6 |
Re: 1935 Ford 15-P
A older roundy-roundy guy I knew told me once, that he used a 37 block with pumps up front and then early heads on backwards to get the water to flow out the back of the block. Making the rear of the engine cooler. (a real dead spot for flow). Now I didn't buy it completely but I did go home and flipped the heads on a 33 motor I had sitting in the garage and the heads will bolt up flipped. No Idea if the compression chambers would/will match up. I guess you can flip the head gaskets also with the small hole up front or back.... so But its a neat story anyway! Last edited by Tinker; 01-21-2019 at 08:26 PM. |
01-21-2019, 05:13 PM | #7 |
Re: 1935 Ford 15-P
Was thinking about the 15-P and Henry Ford's ambition to put folks into cheap, easy-to-fly airplanes like he did with cheap automobiles.
In 1935 everyone owning an airplane was a common fantasy. But, unlike driving a car, flying was a little more complicated even back then. Not sure what the total thinking was with the 15-P ... probably involved reducing the skill level required to fly an airplane. Make it hard to stall (aerodynamic), make it spin-proof, make it require less coordination of controls ... stick and rudder stuff. The automobile type steering wheels in the cockpit suggested it could be "driven" like a car. Whatever they were thinking with the tailless, flying wing type design, they lacked the materials and technology to make it a flying success. Today, we have advanced composites, refined engines and computers that make drones, driverless cars, and passenger aircraft with auto-land systems. ... we also have iPhones, iPads ... iWatches. How about Apple iPlanes? Get your 7 year old grandson to program your next vacation and strap in. Driverless Uber service could become Uber Airlines with custom pilot-less routes to places like Hahira, Georgia. (Henry would be proud of this kind of thinking.)
"Remember that when it comes to intelligence, half of all of us are below average." |
11-13-2019, 01:22 PM | #8 |
Re: 1935 Ford 15-P
The heads do appear to be installed with the water outlets at the rear of the engine. The engine is installed with the rear pointing forward because power is always transmitted via the flange on the rear of the crankshaft. The "abnormal-appearing" reversed pitch on the propeller is likely the result of the normal crankshaft rotation of a Ford flathead feeding a gearbox to slow propeller speed, which would also reverse the rotation of the propeller. An interesting rig, for sure. DD |
01-19-2019, 11:53 AM | #9 |
Re: 1935 Ford 15-P
01-19-2019, 12:55 PM | #10 |
Re: 1935 Ford 15-P
If you look at the fan belt it appears to still be running front block mounted water pumps. The early head appears to have a custom hose fitting to fit in the place of the head mounted pumps.
01-19-2019, 01:02 PM | #11 |
Re: 1935 Ford 15-P
Very futuristic for the times, very nice looking. To bad it didn't suvive.
01-19-2019, 03:14 PM | #12 |
Re: 1935 Ford 15-P
I doubt very much that the 221 ci engine could produce any wgere near 120 HP as the 239 only produces 80 hp. I think the plane could be a nice one with the right amt of power, but not that easy to fly. I never had a pilot license, but learned to fly a Cessna 182 that belonged to a friend of mine. We built a runway alongside my shop and flew all over the place for years. The first plane he had was a 47 commonwealth with 85 hP and was very under powered. Nearly lost it flying out of the white field at Hershey. Over weight on a hot day. Learned allot obout DA that day.
01-19-2019, 05:01 PM | #13 |
Re: 1935 Ford 15-P
I don't see how they ever got the Center of Gravity (CG) anywhere near correct with the heavy engine behind what looks to be the wing spar position. I'll bet it was a doozy to fly if it did ever fly at all.
01-19-2019, 05:36 PM | #14 |
Re: 1935 Ford 15-P
Yeah, along with those humongous landing gear struts. A bit of drag there.
01-19-2019, 07:26 PM | #15 |
Re: 1935 Ford 15-P
The landing gear and pilot's weight likely put the CG where it was supposed to be. The drag flaps used instead of a rudder would have made low speed handling very tricky if not impossible. I'm sure Jack Northrop looked the design over along with the German and Russian designs before he started tinkering with the idea a few years after. His N-1M was a flyable design but it has pusher props that can be manipulated for some directional control as well. Ford experimented with aluminum flathead engines several times but they didn't make very many of them. They would have been a lot better off with a conventional design. The problem was that they were looking for a design that would be simple enough that they could produce it for little more cost than a model B car but it was a bit too minimal to be a safe design to fly. The crash in the initial testing pretty well tells the story. I'd love to have the engine though.
Pietenpol proved that even a model T engine would power an aircraft at 20 HP but I think I'd prefer a Model B engine myself. Last edited by rotorwrench; 01-19-2019 at 07:36 PM. |
01-20-2019, 04:08 AM | #16 |
Re: 1935 Ford 15-P
The other photos in the link show it to be a flying wing design. The engine isn't really behind the wing as much as you might presume by just looking at that one pic.
From all accounts, it didn't fly very well. I'm no aero engineer, so don't treat my comment as gospel. Mart. |
01-20-2019, 09:04 AM | #17 |
Re: 1935 Ford 15-P
“ Learned allot obout DA that day.“ What’s “DA”?.....Mark
01-20-2019, 10:22 AM | #18 |
Re: 1935 Ford 15-P
PA maybe since it was at Hershey.
01-20-2019, 11:28 AM | #19 |
Re: 1935 Ford 15-P
Density Altitude https://www.aopa.org/training-and-sa...nsity-altitude
01-20-2019, 11:39 AM | #20 | |
Re: 1935 Ford 15-P
