02-12-2023, 06:28 PM | #1 |
What the heck is that?
I stopped in a local tire shop that has been here for at least 75 years. No one is over 50 years old and most under 30. I had a 1936-39 wide 5 rim in my hand. The oldest fellow was quick to expound on his great wisdom. "That is a Volkswagon wheel". It appears to me I will be dismounting and mounting tires. Maybe I will buy one of those HF changers and make an adapter. Always like a new project. Keeps me young (and sore) I guess. LOL
02-12-2023, 07:13 PM | #2 |
Re: What the heck is that?
I believe that the old bugs did have the same bolt pattern as the wide fives. My neighbor has a trailer with a 36/37 rear end and VW wheels.
Red |
02-12-2023, 07:28 PM | #3 |
02-13-2023, 11:04 AM | #4 |
02-12-2023, 07:21 PM | #5 | |
Remove the bag. The first one took about 15 minutes. After that, I did the remaining four in about 45 minutes.
02-12-2023, 07:51 PM | #6 |
It's very convenient to have your own machine; just be careful who you tell or you will have a constant stream of visitors. |
02-12-2023, 11:06 PM | #7 |
I have an old Coates Tireman. All manual, but it makes the job almost effortless after doing so many on my knees with tire irons. I paid 80 bucks at the portland swap meet and it came with all the tools. On Thursday a couple of friends came by and used it as one guy wanted the tires, other the rims. For me living at the far end of a remote place, it's a social benefit as well. Mine won't do the dually offset wheels so Gonna try the Kube's garbage bag trick as I do them on the shop floor. Get us a pic of the wide 5 adapter when it's done.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
02-13-2023, 05:40 AM | #8 |
If you are making a wide 5 adaptor the Bolt circle is 10-1/4". I made one and thought it was 10" and wondered why the wheel wouldn't go on.
02-13-2023, 07:27 AM | #9 |
get an old front drum it can be held in a tire machine
02-13-2023, 09:19 AM | #10 |
my son works for firestone/bridgestone and they have a tire machine that clamps the rim, not the center-is uses a plastic shoe so it does not make the rim--also they have sort of a clamp system to break down the bead
02-13-2023, 11:18 AM | #11 |
I bought a Coats 10-10 air operated machine for $80 at a swap meet from a guy who dismantled gas stations many years ago. He had a whole trailer load of them. Still works great and I bought a couple of plastic accessory tools for using on chrome or aluminum wheels. In this state, studs have to be off by April 1 so twice each year I hear from friends needing to switch. I told them to buy a pair of extra wheels and we won't have to dismount/mount/balance all the time!
02-13-2023, 02:58 PM | #12 |
Remember to remove the studs, When preparing Road Kill.
02-13-2023, 03:53 PM | #13 | |
The machine they use doesn't know what the wheel came off. Martin. |
02-13-2023, 04:30 PM | #14 |
Speedway sells an adapter - I just gave my local tire shop mine to borrow when I had them do my wheels/tires on the 36.
it worked really well and they were able to use it to balance them too. Pat |
02-13-2023, 04:40 PM | #15 |
Most "they" do not have the right equipment to hold the rim with such a large center hole. "They" do not have adapters to hold the wheel for balancing. That is why you have to come up with an adapter. The newer machines will hold the rim but not the balancers. IMHO
02-14-2023, 03:37 PM | #16 | |
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35). |
02-13-2023, 05:35 PM | #17 |
Adapters were sold by Dick Spadro. The speedway ect. adapters have 5/8" lug studs for circle track wheels, but will work. Old topic here. Newc
02-14-2023, 09:54 AM | #18 |
Easy way to determine if it's a VW or wide five wheel. A wide five will go over your head but a VW won't. Of course some heads may vary.
02-14-2023, 03:05 PM | #19 |
34fordy, Have the Dick Spadaro adapter for you to use to use free of charge. My shipping to you at no charge and return to me on your dime. My new tires are are being mounted and balanced by my local guys this week. Always willing to help a fellow 'Barner.
