09-19-2014, 08:33 AM | #1 |
tubular rivet tool UPDATE
for those of you that have purchased the tonka tubular rivet tool c clamp style....what size die did you order with it? i need to do the hood leathers and bumpers.
thanks here is a link to the ebay ad http://www.ebay.com/itm/201074425251 Last edited by Mitch//pa; 10-06-2014 at 01:08 PM. |
09-19-2014, 08:36 AM | #2 |
Re: tubular rivet tool
On mine, I did not have that option. One side has a ball machined into it and the other side is just a concave shape.
09-19-2014, 08:40 AM | #3 |
I just use an air gun bb and a c-clamp. Works for me.
09-19-2014, 08:39 AM | #4 |
hmmmm
so what would you do if you needed one |
09-19-2014, 09:13 AM | #5 |
Here is what I use. Works for brake linings as well. Much less expensive. Gar Williams
http://www.skygeek.com/aircraft-tool...-tool-kit.html |
09-19-2014, 09:19 AM | #6 |
09-19-2014, 11:27 AM | #7 | |
yes it was discussed recently and mentioned about the ease of use vs the hammer style when working with a restored delicate hood... the cost is no object i just want the best one man with two hands tool available . |
09-19-2014, 12:00 PM | #8 |
I use the Tonka tool and while a little pricey the results are great. I use the 1/8 die set.
Oklahoma City Model A Restorers Group. |
09-19-2014, 12:31 PM | #9 |
09-19-2014, 06:10 PM | #10 |
1/8" may work ok, but all the tubular rivets I can think of that are used on the body and hood were 9/64". Consequently that is what I use for tooling.
http://www.abarnyard.com/ |
09-19-2014, 07:37 PM | #11 |
I believe the rivets should be rolled and not just smashed if you are going for the original look. The tool head has a special shape. I thought this had been discussed on FB before and a photo posted but couldn't find the thread.
Here's the idea - http://www.clevedon-fasteners.co.uk/...-rivets-5.aspx A tool used with a hammer - http://www.jmurrayinc1944.com/produc...ubular-rivets/ |
04-14-2017, 10:38 AM | #12 |
The links in my post above don't work anymore, here's a view of the rivet and tool that shows the rolled rivet.
09-19-2014, 07:30 PM | #13 |
Hanson Rivets sells the squeezer dies - made for brand of manual squeezers that they sell.
http://www.hansonrivet.com/riveting-squeezer-dies.htm These can be adapted to other squeeze machines. Such as below like mine... Joe K
Shudda kept the horse. |
09-20-2014, 09:47 PM | #14 |
thanks for the replies
i contacted the ebay seller who knows quite a bit about his product and rivets in general. he seems to think a 5/32 die would work good. i am going to send him a sample 9/64th rivet then we can decide what works.. i will post the outcome thanks Last edited by Mitch//pa; 09-21-2014 at 04:03 PM. |
10-06-2014, 01:04 PM | #15 |
tool and info update
the ebay seller in post #1 is first class. he worked with me to figure out what size die is needed to do a proper job. i sent him a couple sample rivets to check out and we went with 5/32 dies. i just did the hood bumpers and corner leathers and it came out primo. now i have to do the floorboard irons and shift plate cover clips this tool rolls the rivets |
10-06-2014, 01:56 PM | #16 |
Re: tubular rivet tool UPDATE
I was kind of fallowing this post and Aerocraft came up with a site to get a tubular rivet tools. I already have five different kinds of the tools but the one that caught my eye was part #A404 on that site, so I bought one and boy is it a nice tool. My tonka one has installed maybe 60 rivets and it is about done. this one is well built and looks like it will last for a long time.
04-12-2017, 10:35 PM | #17 |
Somehow I missed this thread when it was new. I also bought the same type as Aerocraft, and it works fine. I always put a drop of oil on the tool to help the rivet roll over smoothly without cracking.
04-13-2017, 12:20 AM | #18 |
I did a hood about a year ago using the squeeze tool and was happy with the results. Here is a quick set of pics showing how I did it.
I think the set was 9/64", but I got several sets, 5/32 and one other. I painted the hood sides and rivets separately to make it easier to polish the sides without worrying about rivets paint burning. Not the way Henry did it, I'm sure, but painting everything separately also gets full paint on the mating surfaces so it will be less likely to have rust stains down the road. a lot of rivets and pieces to paint separately a bit of blue tape on each rivet before squeezing. finished handle, sorry about the iPhone reflection. finished hook latch clip The round rubber bumper was initially too long and had to be ground down a bit by trial and error to keep it from popping the latches. |
04-13-2017, 06:21 AM | #19 |
Here is a pic of the tool with the 5/32 die installed
04-13-2017, 03:23 PM | #20 |
I have a couple of these hanging around, do you think they would do the same job if I could get hold of the dies and modify the clamp ?
Love a Lot, Trust a Few
Always Paddle Your Own Canoe |
