08-20-2018, 06:07 PM | #1 |
Putting a V8 in a model a
I have been thinking about putting a V8 in my 28 roadster sometime in the future, but I don't know how to go about it and what fits. Has anybody around here done this to a 28 Roadster or similar example? I want the setup that is the easiest to put in.
08-20-2018, 06:21 PM | #2 |
Re: Putting a V8 in a model a
I have heard of this modification, but all research has shown it just cannot be accomplished.
08-20-2018, 06:31 PM | #3 |
X2.
1929 Coupe 1930 Coupe 1935 Ford 5 window coupe |
08-20-2018, 06:36 PM | #4 |
Ditto!
Bob-A |
08-20-2018, 06:35 PM | #5 |
I have a couple model A's with small block chevies. They require a recessed firewall. I think a flathead might fit though.
08-20-2018, 08:27 PM | #6 |
08-21-2018, 09:29 AM | #7 |
Small block chevies are all the same from '55 to about '96. Doesn't matter if it's a 265 or a 400, same block. We went on a hotrod tour with a guy that had a '29 coupe with a flathead-8. Was a nice car but he was still dropping a gear on every hill, even the relatively mild hills. Would be an expensive job for little gain IMO but it all depends on what you want. Don't pay no mind to all those that are ragging on you for wanting the car to be what YOU want. It's your car. make it the way you want it. I had a guy a few weeks ago on another forum post pics of a beautiful '30 couple stating that he took it for a drive and "now to pull the fenders and boards off". He wants to hotrod it. Kinda breaks my heart to see such a nice original get modified but it's his car to do as he pleases. BTW I would be curious how many of those that are giving you the gears about modifying your car added a second tail light and signals to theirs?. Seat belts, speed parts, powder coated wheels, 12 volt etc. Mods are mods. It's either how Henry built it or it isn't.
08-21-2018, 09:45 AM | #8 | |
08-20-2018, 06:47 PM | #9 |
DO SCREW UP A PERFECTLY GOOD MODEL A. Find one that is fiberglass body and put on a frame built for a hot rod
08-20-2018, 06:50 PM | #10 |
ditto
'30 Coupe |
08-20-2018, 08:23 PM | #11 |
08-20-2018, 06:47 PM | #12 |
#1 Ask this question on the Flathead Forum
#2 Find the book "Building a Traditional Ford Hot Rod" by Mike Bishop and Vern Tardel.
Don't never get rid of nuthin! |
08-20-2018, 06:57 PM | #13 |
Lot's of info about this on the HAMB site .
https://www.jalopyjournal.com/forum/...n-an-a.875648/ |
08-20-2018, 08:23 PM | #14 | |
08-20-2018, 07:02 PM | #15 |
Hot rod stuff the hamb is your friend. Jalopyjournal.com
08-20-2018, 08:44 PM | #16 |
Have you considered modifications to your 4 banger?
Charlie Stephens |
08-20-2018, 09:08 PM | #17 |
08-20-2018, 09:34 PM | #18 | |
Attached are a picture of a modified engines (neither of them mine). Just be sure to not try and pump out too much horsepower or reliability will suffer. The speed equipment on both of these engines are probably reproductions you don't have to scrounge for original speed equipment. The flathead is a "Thomas" equipped engine and the overhead is probably a Riley two port by Charlie Yapp of the Secrets of Speed Society (SOSS). The Roof, Cragar and Four Port Riley's are also currently reproduced (and probably a couple of others). Charlie Stephens Last edited by Charlie Stephens; 08-21-2018 at 12:26 AM. |
08-21-2018, 09:15 AM | #19 |
Actually a restored, stock Model A looks a lot like everyone else's restored, stock Model A.
All steel from pedal to wheel |
08-20-2018, 09:45 PM | #20 |
I agree with Charlie Stephens. I recently put a Model B engine with a Roof overhead conversion in a '31 Slant Windshield. It required no modifications to the body or chassis. I think the Roof and Riley topped four cylinder engines look better than a V-8 in a Model A. Either of these heads put out plenty of power for road cruising and air conditioning if you so desire.
In the end, when you sell your car, you may find it is worth more if it is not "cut up" to accommodate a V-8. JMO Good Day! Last edited by Dave in MN; 08-22-2018 at 03:08 PM. |
