08-06-2023, 01:05 PM | #1 |
59ab 80 over cam bearing
First time posting but been reading for a few years. I am having a machine shop build a 59ab for my 36 5window and got the call I needed 80 over cam bearings. I been searching for about three weeks and read all articles I could find and in one it listed NOS part numbers as 01A-6261-D and 01A-6262-D and I found these numbers for sale and I purchased. Now the boxes have D2 instead of D at the end of the part number. Does anyone know what the 2 stands for? Could it be a different ID?
08-06-2023, 02:24 PM | #2 |
Re: 59ab 80 over cam bearing
The "2" indicates the part was sourced from a different supplier. It is interchangeable with the same basic number (D).
08-06-2023, 03:14 PM | #3 |
Thanks
08-06-2023, 03:44 PM | #4 |
I hope the machine shop is really trying to say you need .20 under bearings. If they ground that much off of the journals, I would be very concerned about the shop and you will need a new cam.
I've only seen .20 under bearings for sale. I've seen anything above that. |
08-06-2023, 03:47 PM | #5 |
.20 inches is a lot of metal. Shouldn't it be .020?
08-06-2023, 03:52 PM | #6 |
08-06-2023, 06:20 PM | #7 |
Ford made and used cam bearings for most combinations of standard, oversize holes in the block as well as undersized journals on the cam. Make sure your bearings match the combination of specifications you need for your block and cam.
08-06-2023, 06:30 PM | #8 |
If they're saying you need .080 oversize cam bearings, then they must be talking about the cam bearing bores in the block. Ford didn't like to scrap things, so I've heard they did over bore certain blocks for special oversize cam bearings (instead of throwing the block away). They obviously made oversize bearings for situations like this.
I've never had a block with oversize cam bearing bores . . . but the day is young! LOL If you cannot find the bearings, they may need to make them from aluminum bar stock. |
08-06-2023, 09:53 PM | #9 |
I have these cam bearings for years and still do and sold many
08-06-2023, 11:35 PM | #10 |
Fred to the rescue again!
08-07-2023, 07:03 PM | #11 |
Fred, could you PM thanks, roncol1957
08-07-2023, 10:06 PM | #12 |
"roncol" ...... Since you only have a total of 3 posts here on the F'Barn, you're not eligible (YET) to send or receive PMs. Ya need 10 posts to qualify for PM privileges. I have posted "barnfind08" (Fred Wilner's) contact info BELOW ..... you're going to have to contact him. Fred has nine buildings stocked with NOS old Ford parts, plus he is one of our own members here on the 'Barn. Fred is a GOOD guy!! Coop Fred Wilner - (barnfind08") SOUTHSIDE OBSOLETE 7136 200th St E. Faribault, MN 55021 (507) 332-6789 . |
08-08-2023, 06:00 AM | #13 |
thanks, i will give Fred a call today
