01-11-2021, 02:14 PM | #1 |
Bullet Wire Connector Help
I'm looking for a source to purchase the bullet wire connector which splits the tail light wire and brake light wire when adding the optional right-hand tail lamp assembly in a Truck (not a commercial car pickup). The wiring harnesses for truck tail lights are different than those used for a car as Trucks typically came only with a single left-hand rear tail light assembly.
I can find the B-14467 wire connector sleeve for connecting two single wires and a double connector which is essentially two of these put together and connected electrically. While the double connector will work, it leaves one open hole and just doesn't seem right. I can't find a Ford part number in any Chassis book I have nor can I find a vendor source. I thought for sure I saw them for sale once, but age and imagination seem to increase every day, so maybe I'm just dreaming. Any suggestions for a source of the 1-2 bullet connector, or a verified Ford Part Number, will be greatly appreciated. |
01-11-2021, 02:26 PM | #2 |
Re: Bullet Wire Connector Help
You should contact Fred at Southside Obsolete, barnfind08 on here, or Michael at Third Gen Automotive. If neither of those two can help, then contact Rhode Island Wiring to see if they can help with what you are looking for.
01-11-2021, 02:26 PM | #3 |
Rhode Island Wire carries those connectors.
http://www.riwire.com/
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
01-11-2021, 03:18 PM | #4 |
