08-08-2017, 10:18 AM | #1 |
41 pickup project
I've been a member here for a while, but my 40 coupe project is more of a Hamb fit. My latest is a 41 p/u with an 8ba and stock rear end and trans.
It needs paint and body work but it does drive, except for lights. I have ordered a complete wiring harness from Tyree Harris. The purpose of this post is to find out if the 40 car gas pedal and linkage will work or is the same as the 41 truck. Also, the cowl vent operator and mount has been cut out and I would like to know what that is supposed to look like. I have some 40 car operator parts that maybe I could adapt. |
08-08-2017, 10:37 AM | #2 |
Re: 41 pickup project
Nice truck; get the wiring done and add a front bumper (for other folks' boo-boo's) and drive it. Heh-heh, it seems everyone BUT Ryan can find one of these.
08-08-2017, 11:57 AM | #3 |
I think Ryan just wants a nicer one.
08-08-2017, 12:47 PM | #4 |
Good move on the wires from Tyree. I rewired my 45 using his wires. Pretty easy to do. My horn doesn't work now, but that may be something else :-)
08-08-2017, 01:58 PM | #5 |
Looks like you got a very important piece on the hood. You have the stock hood handle. Tough to find and expensive if you can find one. Nice project. The cowl vent operating mechanism is pickup only and should be the same from '40-'47. Hopefully the dash bracing has not been removed as the mechanism bolts to the bracing. If you want a nice little book on the '40-'41 pickups contact the Early Ford V-8 Club; www.earlyfordv8.org. The book is $10 and well worth the money.
08-08-2017, 02:14 PM | #6 |
08-08-2017, 06:08 PM | #7 |
The spoon type pedal should be correct
08-11-2017, 01:47 PM | #8 |
Here are some pictures of the work being done. I still need some pictures of the cowl vent mechanism.
08-11-2017, 11:32 PM | #9 |
here are some pictures of a 1940 PU cowl vent lever.
08-08-2017, 05:10 PM | #10 |
I always check the part #s in the car & truck catalogs . If they are the same you got your answer !
08-12-2017, 03:36 PM | #11 |
Gas pedal is 40 to 47 V8 for certain but i also think 35 to 39 is the same for trucks only. The 4 cyl and 6 cyl gas pedal is different
08-14-2017, 04:06 AM | #12 |
My truck was originally a 6 cyl. The front crossmember has been changed but it still has the 6 cyl radiator mounts and hood.
08-14-2017, 04:51 AM | #13 |
By chance does your truck have the 6 cyl front fender braces? I got a truck here that has all the 6 cyl front end pieces but has a V8 motor and fender brace ( hood latch, grill crossbar, 6 cyl lower chin, inner fenders with the 6 cyl reinforcement, extened radiator mounts which have 2 sets of holes and the 6 cyl front crossmember), doesnt show any sign of ever having a 6 cyl motor? Motor looks like its never been out of the chassis, has alll the splash pans intact.
08-20-2017, 09:53 PM | #14 |
here are pix of the vent operator. I'll post pix of the radiator mounts here tomorrow
08-21-2017, 02:38 PM | #15 |
skidmarks, here are some pix of the 6 cyl radiator mounts and the 6 cyl hood latch. the last pic is the modified V8 upper grill support to fit the hood latch.
08-14-2017, 06:11 AM | #16 |
Here is a few pics that may help.
08-20-2017, 09:21 PM | #17 |
Thanks Buzz; These are great pix and helped a lot.
05-13-2021, 02:10 PM | #18 |
I thought adding some pix to an old post might add info about using a T70 transmission , from an F 150, in a V8 Ford chassis without trans mods might be useful. These are from my 41 pickup build. 59A engine and open drive banjo rear. the green color is from the storage building.
05-13-2021, 02:25 PM | #19 |
My trans is the RTS BV . I used an MEC adapter Fh to top loader Ford trans; stock 41 p/u clutch linkage and flywheel (diaphragm PP) stock throwout bearing, stock clutch and brake pedals (dual chamber MC)
06-08-2021, 05:05 PM | #20 |
I just recieved my new cam for the truck. I asked Pete for a recommendation and I sent a cam to be reground to 1007B specs. Beautiful job! Thanks again ,Pete.
