Old 06-30-2015, 05:15 PM   #1
bosstime2
bosstime2's Avatar
Default New points not lining up
Putting new orginal style points in my uncles car...they don't line up perfectly. Any ideas?
1929 Open Cab Pickup
1930 Standard Roadster
1936 Buick Special Trunk Back Sedan
bosstime2 is offline   Reply With Quote
Old 06-30-2015, 05:22 PM   #2
Mitch//pa
Default Re: New points not lining up
you can tweak the point holder where it mounts to the plate.. i have to do it all the time
Old 06-30-2015, 05:23 PM   #3
bosstime2
bosstime2's Avatar
Ok thanks
Old 06-30-2015, 05:25 PM   #4
Brian T
Brian T's Avatar
Hello bosstime2,
Turn the plate over and loosen the 2 screws, you can then swivel the mount around to align the points.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 06-30-2015, 05:27 PM   #5
jetmek
try assembling it with the point block screws snug so you can still adjust the point block. get a rough point gap setting on the lobe and move the point block for best alignment square to the moving point. Think Ive actually had to bend the arm slightly to get them square to each other.
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 06-30-2015, 07:05 PM   #6
bosstime2
bosstime2's Avatar
Hey guys thanks for the tips.... She runs beautiful
Old 06-30-2015, 07:12 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Be sure to use lube on the cam/rubbing block. I smear some lube lightly over the entire cam to keep rust away.
Old 06-30-2015, 07:17 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Make SHURE the point arm pivot post is not wobbly? loose. They are staked under the plate. Just TAP-TAP-TAP, with a blunt center punch. Mine were BOTH loose. It's a COMMON problem that's easily overlooked!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-30-2015, 07:40 PM   #9
bosstime2
bosstime2's Avatar
Tom I definitely will lube that cam and rubbing block. Bill W....thanks for a great tip as well. Car runs very well and we went for a mile drive and started hearing a terrible thud in the driverside rear. We both thought it was a flat spot on the rear tire. We got home to find that all the lug nuts were about two turns from falling off. Thankfully the wheel didnt fall off and the threads were ok. I tightened up all four wheels. My uncle had just aquired the car last week and it hadnt ran in 6 years
Old 06-30-2015, 07:43 PM   #10
Mitch//pa
its always a good thing to ck all the fluids and do a safety check like a state inspection before driving
Old 06-30-2015, 07:45 PM   #11
bosstime2
bosstime2's Avatar
I agree with you Mitch. I guess the excitement got to us.
Old 06-30-2015, 08:08 PM   #12
Tom Wesenberg
I hope the lug nut holes didn't get enlarged from driving with loose lug nuts. If they did, then you can use the washers to fill the gaps.
Old 07-01-2015, 10:30 AM   #13
Richard Lorenz
Looking at your points picture, I believe that you may have to enlarge the holes underneath the point block in order to move the block outward enough to make the points match in location.
Richard Lorenz is offline   Reply With Quote
Old 07-01-2015, 10:38 AM   #14
Mitch//pa
one hole is already elongated
Old 07-01-2015, 02:02 PM   #15
BILL WILLIAMSON
Sometimes we don't know/forget features like this one. We don't often get into the innards of the distributor & it's good to have an old spare to diddle with & see if you can strip it down & put it back together PROPERLY. Same goes with carbs or "maybe" an old spare transfusionmission. The Dogs' excuse is that he has NO THUMBS!!
Bill W.
Old 07-01-2015, 03:04 PM   #16
Brian T
Brian T's Avatar
Bill W.
This for sure is the best advice for a model A owner to learn and repair these and other cars, I have earned my living in auto repair since the mid 50s, advancing up the learning curve over the years never knowing that I would ever end up adding software to cure an idle problem, (no challenge in that.).
Buying dirty rusty distributors, carburetors, etc at swap meets and turning them into usable items is a challenge that satisfies me and helps others,--- in addition finding parts that others are looking for helps keep valuable parts out of the scrap melting pot.
The dog could have had my thumbs in my apprentice days, my shop foreman accused me of being all thumbs LOL.
Old 07-01-2015, 06:17 PM   #17
Ron W
Ron W's Avatar
I would return them and get some good ones.
Ron W is offline   Reply With Quote
Old 07-02-2015, 05:01 AM   #18
Tom Wesenberg
The points look fine. He just needs to loosen the two screws holding the points block so he can shift the block into alignment. Also the points pivot should get a drop of oil and the rubbing block gets some lube.
Old 07-01-2015, 06:19 PM   #19
Ron W
Ron W's Avatar
Check the holes in the plate. If they are off get a new plate. Ron W
Old 07-02-2015, 06:12 AM   #20
Ron W
Ron W's Avatar
I guess I didn't realize the block was adjustable. I've never had to move mine. Thanks Tom. Ron W
