#1 |
I picked up this generator ($10) at Asheville, mainly for the front fan mount, and the seller said the oblong cutout was for radio equipped cars. Can anybody confirm, or add anything about it?
Thanks! |
#2 |
The seller was correct in his description of the cutout.
#3 |
I always thought that one was the Heavy Duty version.
#4 |
Could be 68-10505 step voltage regulator and cutout assembly all 8 cyl police or bus 1932-37.
Bob |
#5 |
Thanks for the responses. He did say it was off a 37
#6 |
#7 |
so if infact it was for a radio, its still just a cutout, and not a regulator, it must have some noise suppression bonus ?
#8 | |
![]() Quote:
#9 |
It is called "Two Rate" It can have the generator charge at two different levels. It is not a true regulator, still a cut out. Is the Ford name stamped into the top and any other identification such as an A or B or BB? These stamping help to identify the various years. All the noise suppression for a radio is in addition to the cut out by using additional condensers.
#10 |
Exactly correct Terry,OH. It is a two step charge relay. When the fitted radio set was turned "ON" then the generator fields were connected directly to ground through one pair of contacts for a higher charge rate because these glovebox or centre control radios draw around six amps. With the radio "OFF" the generator fields were connected through the other contacts and a series resistor to reduce the charge rate of the generator to a lower setting. This was internally sensed using the current winding inside the reg. The base charge rate was still adjusted with the third brush. These oval cut outs were introduced in Jan. 1934 and made obsolete after Jan. 1936 and generally only used when cars were fitted with radios. They gave trouble and Ford mechanics did not always have the tech ability to set them properly and many were replaced with the normal round Ford cut out. They are fairly scarce today and bring good prices. Mechanics and electricians still don't understand how to set them up even today. Regards, Kevin.
#11 |
There is a good explanation of this two rate relay with pictures and diagrams
in the March 1934 Service Bulletins. Bob |
