Old 11-09-2011, 08:52 PM   #1
700rpm
700rpm's Avatar
Default Model A wiring and The Mushroom Factor
We've all experienced The Mushroom Factor, I'm sure. Where you start out on a simple job, like tightening your lug nuts, and it mushrooms until you end up practically restoring the car before you're done?
Two weeks ago (!) I decided I had to figure out my malfunctioning tail light/brake light situation. With some elementary probing I discovered the lights were wired just opposite of what they should be. Changed that, and the tail light worked. But the brake light didn't. Took the brake switch apart, wiggled it, put it back together. Voila! Tail light and brake light!
But the parking lights didn't work. It was then I determined I had a home-made wiring harness for a one-light system wired into my Twolight headlights.
And so on. Today, two weeks (and about $200) after starting on a relatively easy tail light problem, I have: torn out the old wiring, put in a new harness, replaced the bogus repro light switch with an original, replaced the chrome reflectors with originals, installed an original dash light, replaced my radiator hoses, and rebuilt my entire steering column with all new gears and bearings (more money). How did I get there? Well, that is an even longer story!
That, my friends, is The Mushroom Factor.
Old 11-09-2011, 10:04 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Model A wiring and The Mushroom Factor
And I bet it was fun! Thanks for "The Mushroom Factor" Great!
www.whidbeymodelaclub.com
Old 11-09-2011, 10:25 PM   #3
JBR
JBR's Avatar
Gee, I always thought it was when "they kept you in the dark and fed you manure."
JBR is offline   Reply With Quote
Old 11-09-2011, 10:46 PM   #4
700rpm
700rpm's Avatar
That's good!
Old 11-10-2011, 08:13 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
Night shift at the Post Office
Old 11-10-2011, 11:37 AM   #6
JoeWay
JoeWay's Avatar
Patrick McManus, who wrote columns for Outdoor Life, referred to this phemonon as "sequences". I get caught up in them all the time, to the point that it's a running joke between my wife and me. Here's a link to a description of Patrick's story on sequences:
sequences
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 11-10-2011, 02:48 PM   #7
Brentwood Bob
Murphy gone amuck. Happens all the time. Bob
Brentwood Bob is offline   Reply With Quote
Old 11-10-2011, 04:49 PM   #8
MALAK
MALAK's Avatar
Yep I've got a pretty big mushroom growing right now. What started as (I hoped) a simple engine fix has grown into something much larger.
MALAK is offline   Reply With Quote
Old 11-10-2011, 06:36 PM   #9
Bill Goddard
Bill Goddard's Avatar
My mushroom started as an inspection of the crank bearing shims . Babbit was found to be falling out. The picturs explain the result.
Bill Goddard is offline   Reply With Quote
Old 11-10-2011, 07:58 PM   #10
JBR
JBR's Avatar
I realize that a bad bearing can cause vibrations, but I've never seen one bad enough to cause the back of the car to fall off.....
Looks like you're doing a nice job of putting her back together though.
Jon
