run the engine in a dark room and observe the distributor and plugs. You will see the leaks on the outside quite obviously. For inner leaks, I use a cutaway distributor cap, available from most suppliers. I think Nu Rex makes it. You can look inside and see the arcing sparks and any tracers if the body is failed. Failures within the car from one terminal to another can be seen by loosening the spark leads about 1/4 inch from the terminals and observing the timing sequence of the sparks as they fire. The rhythm should be consistent and even. Continuity tests work well on stable failures, but on intermittent failures, the odds are against your finding it with a simple test meter. ( a sub section of Murphys Law)
