Old 04-29-2014, 08:06 AM   #1
Mike
Mike's Avatar
Default New head
I am getting a new 5.5 high compression head, which head gasket do you prefere ? And why ?
Mike
Mike is offline   Reply With Quote
Old 04-29-2014, 09:00 AM   #2
Gary WA
Gary WA's Avatar
Default Re: New head
Copper Felpro 7013 R4 with copper spray. proper torgue technique I do mine always Cold Engine.
www.whidbeymodelaclub.com
Old 04-29-2014, 10:00 AM   #3
CarlG
CarlG's Avatar
Per Snyder's instructions:
You must use the 1932-34 "B" style head gasket with this cylinder head.
I use their "Premium Gasket"
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-29-2014, 10:24 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Mike
Ask the vendor for the recommended gasket.
Old 04-29-2014, 10:56 AM   #5
TinCup
TinCup's Avatar
Mike I have installed this both ways. I like the Premium gasket that Snyder's sells but have had 3 on different cars blow gaskets in the last year on fresh installs. Don't really know why and they all blew in different areas. Consensus around this neck of the woods is the all copper gasket is more reliable. I still am running the Premium gasket on my coupe without issue.
TinCup is offline   Reply With Quote
Old 04-29-2014, 11:28 AM   #6
Dave in MN
Dave in MN's Avatar
This one works well.
From Snyder's:
'B' Head Gasket
  • Head gasket for the 32-34 4-cyl. Will also work on the Model A. U.S.A.
    Part NumberSpecificsPrice B-6051-CCopper with Graphite Core
    1928-34$25.50 / ea.
Dave in MN is offline   Reply With Quote
Old 04-29-2014, 02:05 PM   #7
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I have the Snyder 5.5 head on my coupe. I installed the recommended felpro gasket twice. It seeped both times around the serial numbers on the block. I talked to an old Model A'er about the problem. He recommended using a quality copper clad Model A head gasket and to coat both sides of the copper head gasket with a thin coat of axel grease. I followed his advice. The head has been on for 6 years and about 14,000 miles with no seepage at all. Further, should you need to remove the head in the future, it will pop right off as there is no sticky sealant involved. JMO
Dick M is offline   Reply With Quote
Old 04-29-2014, 03:20 PM   #8
ronn
re Dick,
axle grease.......... I like that. Makes a heck of a lot of sense.
Old 04-29-2014, 03:55 PM   #9
TinCup
TinCup's Avatar
First time I reinstalled the head on my coupe my father told me same thing. He said it is what they did. I didn't understand the science but I trusted him completely and installed the used copper gasket that way. Never had a problem with it.
Old 04-29-2014, 09:12 PM   #10
glenn in camino
glenn in camino's Avatar
I use the copper clad head gasket with lots of copper coat spray. I usually retorque hot and then again the next day cold, but I don't think that really matters. Just retorque several times over a couple of days.
Old 04-30-2014, 05:31 AM   #11
James Rogers
James Rogers's Avatar
That is incorrect. I run one and use a Best gasket or Fel-Pro 7013 and have absolutely no problems. Done it this way for years and have installed probably 50 this way and never had a complaint.
James Rogers is offline   Reply With Quote
Old 04-30-2014, 03:50 PM   #12
Mike
Mike's Avatar
Thank you everyone !!
Mike
Old 04-30-2014, 04:07 PM   #13
CarlG
CarlG's Avatar
Originally Posted by James Rogers View Post
That is incorrect...
I only said that is what Snyder's says. It works for me, but then what do I know, I've only done one engine, not 50. And I was just following the manufacturer's instructions.
Alaskan A's
Old 04-30-2014, 04:57 PM   #14
machine girl
Has the Snyder head been out long enough to have done 50? (just asking)
machine girl is offline   Reply With Quote
Old 04-30-2014, 05:06 PM   #15
Mike
Mike's Avatar
Where do I purchase a copper felpro 7013 r 4 gasket
Old 05-01-2014, 05:09 AM   #16
colin1928
colin1928's Avatar
You only need the stock felpro 7013 the R4 version from my memory is for engines bored to 4 inch
Another good gasket is Best 509 I use this why I have changed Valves
colin1928 is offline   Reply With Quote
Old 05-01-2014, 06:59 AM   #17
James Rogers
I understand that and didn't mean any insult. I just don't understand why a distributor would suggest something they don't have any reasonable proof of. I guess it sells a more expensive part.
Old 05-01-2014, 07:00 AM   #18
James Rogers
Any good auto parts should be able to order one for you.
