Old 07-02-2011, 05:30 PM   #1
A440cuda1
A440cuda1's Avatar
Send a message via MSN to A440cuda1 Send a message via Yahoo to A440cuda1
Default Finally Brought the Model A home today
Well I finally got the 1931 model A pickup home today. Yes, I did take the hood off as soon as it was in my drive way, i felt the need to showoff the little banger around town. Plans are to hop up the banger a bit and drive the tires off of it. Thanks for the warm welcome from my 1st intro post.
-Eli
A440cuda1 is offline   Reply With Quote
Old 07-02-2011, 05:39 PM   #2
48Ratfink
48Ratfink's Avatar
Default Re: Finally Brought the Model A home today
I wish I were there to see Your smile!! Enjoy!
48Ratfink is offline   Reply With Quote
Old 07-02-2011, 05:45 PM   #3
A440cuda1
A440cuda1's Avatar
The smiles were great untill i forgot to turn the gas on and got stuck in the middle of a 6 lane (3 each way) intersection....still have a few things to remember on this old truck.
Old 07-02-2011, 05:50 PM   #4
48Ratfink
48Ratfink's Avatar
Thats the most fun part! I had to walk home one Hot Sunny afternoon here in Alabama,after trying to take the Wifey out to eat! She sat with the A while I was gone!
Old 07-02-2011, 06:14 PM   #5
jimvette59
jimvette59's Avatar
Good luck. Cuda 1. I am sure you will really find out by removing the hood the cab will be about 40 degrees cooler. The old timers would let the hood sides flap over the fenders to let the engine heat escape before hitting the fire wall.
jimvette59 is offline   Reply With Quote
Old 07-02-2011, 08:20 PM   #6
A440cuda1
A440cuda1's Avatar
In this 110 degree az heat, 40 degrees cooler will be very welcome.
Old 07-02-2011, 08:42 PM   #7
BeverlyHillbilly
BeverlyHillbilly's Avatar
Nice truck..congrats!
BeverlyHillbilly is offline   Reply With Quote
Old 07-02-2011, 08:57 PM   #8
Chris in WNC
Chris in WNC's Avatar
it didn't work that way for me. if it is hot enough to open the windshield, you will find it RAISES the temperature in the cab by 40 degrees rather than lowering it.
took our Coupe out for a test drive in the Florida summer heat one day while the hood was off, it was so hot I had to close the windshield.....
our next Model A has arrived.....
Chris in WNC is offline   Reply With Quote
Old 07-02-2011, 09:00 PM   #9
TinCup
TinCup's Avatar
What a peach. I wouldn't change a thing.
TinCup is offline   Reply With Quote
Old 07-02-2011, 09:22 PM   #10
Jim Parker Toronto
Jim Parker Toronto's Avatar
Good looking truck, just drive it like you stole it!!!!
Jim Parker Toronto is offline   Reply With Quote
Old 07-02-2011, 10:01 PM   #11
CWPASADENA
CWPASADENA's Avatar
Looks like a really nice straight truck!
Have fun,
Chris
CWPASADENA is offline   Reply With Quote
Old 07-03-2011, 12:50 AM   #12
A440cuda1
A440cuda1's Avatar
It really is just a nice old truck, spent all afternoon doing a light shake down run around town. Nothing to serious, only noticed my brakes are out of adjustment a little, I have a very slight oil leak around the timing cover and my carb leaves a couple drips from the bowl gasket after you shut it off.
Old 07-03-2011, 08:07 AM   #13
Patrick L.
Patrick L.'s Avatar
Anyone that has an old Ford and a big-block Plymouth has to be OK !!
Old 07-03-2011, 08:21 AM   #14
jimvette59
jimvette59's Avatar
Duhha don't open the wind shield. I had mentioned the side curtains flapped open.
Old 07-03-2011, 10:07 AM   #15
IrishHills
IrishHills's Avatar
I Like !!!
IrishHills is offline   Reply With Quote
