Old 06-20-2011, 01:21 PM   #1
48Ratfink
48Ratfink's Avatar
Default 31 Gas gage
How hard is it to rebuild the fuel gage in a 31 Coupe? I ran out of gas yesterday so I guess this needs to be My next fix!
48Ratfink is offline   Reply With Quote
Old 06-20-2011, 01:24 PM   #2
RonC
RonC's Avatar
Default Re: 31 Gas gage
Not hard. You need the tools to remove the guage. Buy the better of the two guage removal tools available. Replace the cork float with a neoprene float.
RonC is offline   Reply With Quote
Old 06-20-2011, 01:42 PM   #3
Louis
1st thing, Make sure you drain your gas tank to below the guage.
Louis is offline   Reply With Quote
Old 06-20-2011, 02:03 PM   #4
Jason in TX
Jason in TX's Avatar
This is what the gas gauge looks like. It's a cork on a wire that is attached to the (F--1/2--E) read out behind the sight glass.
- Remove the dash panel with the Ammeter/key switch
- Unscrew gas gauge it from the front of the tank
- Replace the cork with the Neoprene float (modern gas kills that cork so it wont float)
- put the gauge back in the tank.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 06-20-2011, 02:39 PM   #5
hardtimes
hardtimes's Avatar
Not hard at all! Follow the others advice given here.
A few of my thots:
-disconnect battery..or master shutoff switch
-make of gig(spec tool);
-buy the best tool available;
-clean everything very clean;
-alternative (improvement)over cork/neoprene float: carb float;a little more work(soldering)but worth no more worries;
-when installing gaskets(whichever)coat all surfaces lightly with aunt jamima surrup(you read right..got this from a barner and it worked perfect) My take is that is allows slight slippage when final firm tightening AND seals great when dry..give it a chance to dry after assembly
Last but not least, make a special tool...from a coathanger. Sharpen on end to a point and with a loop for holding on the other end. Shine you flashlight into the (nearly) empty tank and gig that dead cork float for removal!
Old 06-20-2011, 06:28 PM   #6
gweilbaker
gweilbaker's Avatar
Not hard my arss! You need good sharp tools to fit the bezel nut. Don't use the repro tools, they will ruin your hardware or break.
GW
gweilbaker is offline   Reply With Quote
Old 06-20-2011, 06:49 PM   #7
Louis
It really is an easy job, I've done two, The 1st, I did not have the right tool's so I used a pair of waterpumps and a ford wrench. No problem, The second I did use the cheap set of tool's from Mike's A- fordable Agin no problem. I guess it depends if it's ever been done on that vech. The two that I did had not been done in a very long time from look's of the cork float and seals.
If I had the tank drained and the tool's out plus the parts...Start to fnish in no rush 20-30 min's.
Old 06-20-2011, 07:35 PM   #8
Ted in MN
"hardtimes" listed it in his post but it bears repeating;
DISCONNECT THE BATTERY OR TURN OFF MASTER SHUTOFF SWITCH!!!!!
Ted in MN is offline   Reply With Quote
Old 06-20-2011, 08:17 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Talking Re: 31 Gas gage
Ratfink,
After you have guage back in, open winshhield and take a longwire hook and pull up on guage wire until float clunks on top of tank. Guage should read "F." If not, remove guage and tweek float wire until it reads "F." When set like this, when it reads "E" you will have about a gallon of gas left. (THEN, CUT A TRAIL TO "BAD BUD'S"FOR GAS)
"THE ASSISTANT GURU OF STUFF"
Old 06-20-2011, 08:37 PM   #10
Tom Endy
Tom Endy's Avatar
You do need the special tools and you need to observe some safety precautions. Don't smoke while you are doing this. Lift the fuse or disconnect the battery. Resist the temptation to use a vacuum cleaner to clean out gauge boss (sparks from the brushes will ignite the fumes sucked into the vacuum).
On my cars instead of using a cork or a neoprene float I used a salvaged brass float out of a Tillotson carburetor. They are small enough to fit through the gauge boss and nothing they will put in the gas will destroy it. I just soldered them on the end of the wand.
Tom Endy
Old 06-20-2011, 09:26 PM   #11
TinCup
TinCup's Avatar
Make sure it travels free and clear. Mine hung up on on the flame arrestor and I ran out of gas on my first outing. It hung on a quarter of a tank. I thought I was getting great mileage. Someone had to win the dummy award that year.
TinCup is offline   Reply With Quote
Old 06-20-2011, 09:48 PM   #12
Charlie Stephens
It may not solve your problem but you can adjust these gauges without removing them. Take something and reach into the tank to bend the wire holding the float. A good method is to take two old brake rods and cut them off about 12 inches from the end that takes the pin. Make a slot in the end to allow the rod to go over the wire holding the float. Push and pull to bend the rod as required.
Charlie Stephens
Old 06-20-2011, 11:12 PM   #13
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by Charlie Stephens View Post
It may not solve your problem but you can adjust these gauges without removing them. Take something and reach into the tank to bend the wire holding the float. A good method is to take two old brake rods and cut them off about 12 inches from the end that takes the pin. Make a slot in the end to allow the rod to go over the ire holding the float. Push and pull to bend the rod as required.
Charlie Stephens
I like that!
Old 06-21-2011, 12:02 AM   #14
48Ratfink
48Ratfink's Avatar
Theres alot of good info here, Thanks for all the replies
Old 06-21-2011, 02:32 AM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
Be aware that some of the repro inner nuts don't fit! I had one that either the threads weren't cut deep enough, or the plating was too thick.
Old 06-21-2011, 07:34 AM   #16
RonC
RonC's Avatar
Also buy the gas guage wrench holder Part #13525 that Bratton's sells. It helps a little if you have a stubborn outer nut. The holder helps tp keep the thin outer nut wrench from slipping off the outer nut. You can lightly rap the wrench to free the outer nut using the holder. Only buy the steel gas guage removal tools. The cast aluminum version tools are worthless.
Old 06-21-2011, 10:05 AM   #17
Jerry Parr WI
Jerry Parr WI's Avatar
I keep hearing that gasahol destroys the cork floats. I know alcohol dissolves varnish that was the original coating but how long before that becomes a problem? I replaced the float in one car with a new cork float about 35 years ago and another over 20 years ago. I run almost exclusively 10% ethanol gas and the gauges are still working fine. How long until this becomes a problem?
Jerry Parr WI is offline   Reply With Quote
Old 06-21-2011, 10:14 AM   #18
1931 flamingo
1931 flamingo's Avatar
No offense, but only you will know on yours. Not a hard job as others have stated. I'd do some preventive maintainance. JMO
Paul in CT
Old 06-21-2011, 11:21 AM   #19
Tom Wesenberg
My original cork was dried and crumbling, so I replaced it about 10 years ago. It's still working fine, but for the past 3 years I only use the good gas.
Old 06-21-2011, 03:13 PM   #20
Model A Man
Model A Man's Avatar
one of the vendors sell a brass float and I have them in both my A's and have had no problems with them
Model A Man is offline   Reply With Quote
