what should the Gav Settings be for a model b carb on my A i removed the helper spring and put all new fule lines in her and she is running like a champ just a bit rich. and dose any one have a decent technique for perging the gass tank without removal
Model B carbs are designed for the GAV to be turned completely closed once the engine is warmed up.
Larry Seemann |
I have a late 31, so I was able to flush the tank pretty easily. Then I installed a dirty leg, which is working great. I'm not sure how you would flush a "prototype" tank, with the gas valve inside?
Thanks for your time. Joe Grobleski Cape Codder |
