Old 05-25-2011, 05:24 PM   #1
mrtexas
mrtexas's Avatar
Default Thomas aluminum head gasket
Macs says use a Model B gasket on a Model A block. I've lined up one of my used copper Felpro Model A head gaskets and why wouldn't that be a good one? Two holes at the top seemed to line up 90%, not 100%.
Anyone know for sure what is the best one for the Thomas head?
Looks like someone before me ran the head without a corrosion coupon. I had to get a couple places welded and the whole head planed. Now the only corrosion left is where there are holes in the head gasket. Got is for about 1/2 price of a new one.
mrtexas is offline   Reply With Quote
Old 05-25-2011, 05:55 PM   #2
nostalgicford
nostalgicford's Avatar
Default Re: Thomas aluminum head gasket
I run a Thomas Alumn head....had lots of problem with copper gaskets....you have three different metals...alumn...copper...and steel...and they react to heat different...I have not had any trouble blowing head gaskets since I went to a Felpro but it was not copper...
nostalgicford is offline   Reply With Quote
Old 05-25-2011, 08:31 PM   #3
PC/SR
I use a Best composition gasket on a Weiand alunimum head, works fine, stock bore. I have seen that the B gasket is a touch wider in the part in the quench area between 1-2 and 3-4, and therefore a bit stronger, but maybe its different manufacturers rather than design. I would be kinda leery of using the copper gasket on aluminum head because of electrolasis (sp) of dissimilar metals. However, I did call a tech guy at Best about using a copper tack spray and he said that would be OK, so I dont know how much copper you need to cause that problem. Use the sacrificial zincs the suppliers sell, whatever gasket you use.
PC/SR is offline   Reply With Quote
Old 05-26-2011, 10:47 AM   #4
Jim Brierley
A 'B' gasket MIGHT fit the combustion chamber better, it also MIGHT hang out into the chamber, so use whichever fits better. I would probably use an A gasket and smooth the sharp edges. Don't worry about only getting 90% of the water passages, that is more than enough.
