Old 01-29-2026, 12:48 PM   #1
Chris Haynes
Chris Haynes's Avatar
Default Model "B" fuel pump
I am looking for a fuel pump that will work on a Model "B" block.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 01-29-2026, 01:13 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Model "B" fuel pump
Place a wanted ad in the SWAP section.There are 2 -3 on Ebay right now.
Old 01-29-2026, 01:15 PM   #3
rockfla
rockfla's Avatar
First, there is a "wanted" section in the "SWAP MEET" part of this site, upper RED tool bar, just right of "The Fourms" heading....where this request belongs
Second, they are out there.....here is one that will need rebuilding and IF you end up getting this one OR another one that needs rebuilding....I would suggest Charlie Schwindler in New York.
https://www.ebay.com/itm/32634378339...Bk9SR7yclK-BZw
It's a rough one
Charlie Schwindler
5845 Cole Road
Orchard Park NY 14127
[email protected]
Old 01-29-2026, 01:38 PM   #4
deuce lover
better one $150
https://www.ebay.com/itm/357295759370
Old 01-29-2026, 02:41 PM   #5
petehoovie
petehoovie's Avatar
Originally Posted by deu[B
ce lover;2434918]better one $150
[/B] https://www.ebay.com/itm/357295759370
Old 01-29-2026, 04:07 PM   #6
ursus
Kind of a side note here, but I met a fellow at swap meet who showed me a Volvo fuel pump on which he modified the pump arm by bending it to conform to that of the Model B fuel pump. The Volvo 4 cylinder B18 and B20 engines were used from the 1960's until 1981. I was told that the pump mounting boss on the block is identical to that of the Model B so essentially a bolt-on installation, aside from the pump arm modification. The Volvo pump thus modified will put out about 2 -3 pound pressure.
Curious to know if anybody here has done this?
