Hello, I have to replace the door latch spring on my 39 Mercury convertible, and I am having a problem in getting the coiled springs to fit. It appears that the spring must be compressed or coiled to fit the lock. I have seen a post about coiling the spring and holding with a clamp (which I will try), but is there any other way to do this? Due to the age of the lock (and the fact that it is a Mercury lock), I do not want to bend/break any tabs to get the spring in place. Any help that you can provide is deeply appreciated.
I remember you posed this question a while back but rec'd no responses. Please post a photo of what you are dealing with, if possible. Do you have a part number? When I replaced the springs on a 1940 Ford door lock, I had to bend the hold down tabs after heating them. If the break, you can braze them back on - which is what I did. Use a very small welding tip.
Also is it the right or left hand door latch. Try a Google search. https://www.bing.com/search?q=1939+m...ANAB01&PC=HCTS Last edited by 19Fordy; 11-15-2025 at 11:07 AM. |
as 19fordy says that's what needs to be done, not hard just a pain.
#4 | |
