where can i find the hard board for the door panel ?
This video mentions using 1/8" plastic material (ABS?) which is available from any plastic supply house or ebay.
https://www.bing.com/videos/rivervie...E45E&FORM=VIRE Edit: Video indicates the 1/8" material is PVC
Making the simple complicated for over 30 years. Last edited by 51504bat; 08-11-2025 at 06:47 PM. |
Here is a waterproof panel board.
https://www.automotiveinteriors.com/...ctCode=cowl-dp |
You can get project board at hobby lobby if you like to be more original. I used 3mm lauan which is thin plywood and can be cut with a utility knife. Seal it with water based polycrylic and then upholster how you like. Lauan is flexible so it can be curved or formed a reasonable amount and can be cut, sanded, glued etc with basic wood working stuff.
I am building a 1939 1 ton express Last edited by ActionYobbo; 08-11-2025 at 07:18 PM. |
Upholstery shops can supply it. I used waterproof masonite in my model A.
