Old 06-30-2024, 03:13 PM   #1
iceburg29
Default Mallory dist
Mallory 2301105h distributor anyone running one in their model A. If so how did you wire it up.
iceburg29 is offline   Reply With Quote
Old 07-01-2024, 10:52 AM   #2
Jim Brierley
Default Re: Mallory dist
With stock Model A wiring, the positive side of the coil goes to the point/condenser terminal on the dist. With other systems, such as 12v. neg ground, the neg side of the coil goes to that terminal and from the ignition switch to the pos side of the coil.
