12-03-2023, 08:33 PM | #1 |
Head/engine pulling adapter and engine stand adapter
Whats the reason that these two items are not available from any of the Model A parts vendors. Everyone says out of stock.
12-03-2023, 09:19 PM | #2 |
Re: Head/engine pulling adapter and engine stand adapter
Can't speak to this particular situation, but as a rule, there are only 1-2 manufacturers for any given part. Usually just one and quite often offshore. All the distributors buy from the same manufacturer. When that company is not currently making the part, or goes out of business, everyone has a stock-out at the same time.
12-03-2023, 10:59 PM | #3 |
A standard stand can be used by bolting to the coolant inlet on the side of the block. Use grade 5 bolts that bottom out in the threaded holes. Add washers if the bolts are too long. Tack weld the arms so that they do not move. Two advantages: You don't have to buy a special adapter. The pan an be completely bolted on without removing the engine from the stand (not possible with the normal adapter).
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 12-03-2023 at 11:05 PM. |
12-04-2023, 12:03 AM | #4 |
Are the two bolts enough to hold up the block? I would be leary of the strength of the block in that area. I have no idea what a complete engine weighs with flywheel and everything.
12-04-2023, 01:50 AM | #5 | |
I used a stand adapter designed by TomW. It uses those two bolts to hold the engine up, but it also has two prongs that extend down to the oil pan and brace against it so that the engine isn't putting a twisting force on the bolts. I also used studs instead of bolts, which made it easier to get the engine onto the adapter while the adapter was already mounted on the stand. |
12-04-2023, 05:13 AM | #6 |
12-04-2023, 07:52 AM | #7 |
Have the Stipe combination head puller/engine lift adapter ,works good.
12-04-2023, 08:24 AM | #8 |
I am only speaking from failing memory here, but didn't Steve Becker purchase AE&R (??) who originally was making some of those tools? If so, maybe a phone call to him?? Also, Bill Stipe (-or maybe it was Tony) was making something similar.
12-04-2023, 11:07 AM | #9 |
I converted my 3 wheel engine stand from a 3 wheel to a 4 wheel by removing the 3rd wheel and replacing it w/a 3 foot piece of channel iron w/swivel wheels on both ends.
12-04-2023, 09:01 PM | #10 |
I recently had the oppertunity to see a K.R.Wilson rebuild stand. It mounted to the water inlet and pins that went into the oilpan rail. I came home and nutered my main rebuild stand. Other than having to touch up the paint on a rebuild it is my best new tool.
12-05-2023, 07:45 AM | #11 |
I made my own puller by taking old spark plug, removed porcelain and bolted an eye bolt through it. Worked well.
12-05-2023, 09:34 AM | #12 |
KR500,
Here is what I know. These adapters and thousands of similar items are made from steel which is cut with Computer controlled automated laser cutters. Parts are then bent to shape (More machines some are custom made for this one job). Assembled in stages using various "custom made" jigs to hold them in place before welding. Then various welds are done to complete the adapters. I know of one such shop which in 2019 employed 80 workers. They are now down to 8 workers and 90% of the machines are idle. After Washington's response to Covid 19 shut down all the companies, the employees went on to other careers and never returned. I wonder how long the owners can pay the bills and leases on all of these automated machines? They cannot find qualified workers to run the machines and they do not have the experienced longtime employees to train anyone willing to learn!! Thinking out loud here: Why were all of the shop classes and Vocational Schools shut down? More things that "Bean Counters" have done to drive the USA out of the manufacturing business! Brent, Yes Steve Becker bought AC&R (Auto Care and Restoration), (as I remember) when they closed. I think that Steve will comment when he returns from Vacation. NOTE: Steve is on vacation but Berts is open for business. Last edited by Benson; 12-12-2023 at 11:35 AM. |
12-05-2023, 09:49 AM | #13 |
I am sure that Tony and Dieter Stipe and A&L are having similar problems finding workers!
12-05-2023, 04:05 PM | #14 |
A friend of mine has just shut down his manufacturing business for pretty much the same reasons you guys are talking about. Don't feel special - it is happening everywhere. After all, accountants (bean counters) are the same all over the world.
As I say, "Accountants have a lot to account for."
12-05-2023, 04:38 PM | #15 |
What everyone states here is true. I attended a high school which had a woodshop, electric shop, machine shop, and an automotive shop. 10 years after I graduated no more shops and the school became a college prep school. I retired in 2017, but continued working part time because tool makers are becoming non existent. We have more equipment today that can economically make short runs of lower production items and cheaper but the programmers still have to be trained as do the machine operators. Many parents didn't want their offspring working on oily machinery, so encouraged college courses. We could encourage immigrants flooding our borders for incentives to learn English and sign up for apprenticeships.
12-05-2023, 06:16 PM | #16 | |
I was a VP at one of the biggest 25 banks in the nation, I think I know how to do business. This ship needs to start to turn, or we are all gonna be in a mess one day. LeBarron -Bonney - who would have ever thought that they would be out of business! |
12-05-2023, 06:59 PM | #17 |
I hear that but I think it is too late to turn the ship. Nowadays, even those responsible for setting school curriculums don't know anything about shops. They didn't exist when they went to school and have no experience where they might have thought "Gee, I wish I knew how to fix this." IMO, It will take something REALLY drastic to bring them to their senses, like a war where we need stuff made NOW, not wait for it to be imported from the country that is most likely going to be the enemy. These bean counters need to learn the difference between increasing prices and increasing wealth. There will be no point making a big profit in a country that is on its knees. See my signatures below. Best I don't get started on this.
12-05-2023, 07:55 PM | #18 | |
