09-16-2022, 03:52 PM | #1 |
help identifying Overdrive
Hey folks,
I'm new to the Model a world and just procured my first car! It's a 29 that's had a couple modifications put on by a previous owner (not the person I bought it from). One of the upgrades is an Overdrive (which the seller knew nothing about). Looking at the placement of the shifter, I don't think it's a Mitchell. There is also something that is affixed to the steering column which is related? I'm looking to just identify which overdrive this is so I can get my hands on a manual. Any help would be great! Last edited by swimmermilo; 09-22-2022 at 11:32 AM. |
09-16-2022, 04:41 PM | #2 |
Re: help identifying Overdrive
I believe what you have is a Borg Warner. They used a lockout cable, which is the knob on the left side of the steering column. They usually were electric operated (solenoid). Yours has a manual lever vertically up thru the floorboards, in front of the gear shift. I have heard of manual operated B-W's but never seen one. Maybe someone else can give you more info on the lever thru the floorboards. Mine is solenoid operated.
09-16-2022, 05:00 PM | #3 |
swimmermilo needs help identifying this Overdrive? |
09-16-2022, 05:33 PM | #4 |
To use overdrive, push in on the big red knob. Let up on the accelerator and throw the lever in the floor to engage the overdive. It sould drop in when the torgue is off the drive line (not on the gas). The big read knob put the unit into freewheeling. Makes shifting way easier once the transmission is warmed up. Even when using 1st, 2nd, and 3rd.
38 mph engine speed with this will make your car travel 55MPH. You can save a lot of wear on your babbit bearing engine. It's a good idea to have cast iron drums, on yur car. Gotta stop... |
09-16-2022, 06:22 PM | #5 |
The photo we need is of what is in the torque tube. It may be a Borg Warner or it may be a Laycock/Volvo set up. The Mitchel can be either cable operated or lever but is seldom both.
09-17-2022, 10:57 PM | #6 |
09-22-2022, 11:34 AM | #7 |
hey folks, sorry for the delay! Here are pics of the underside. You can see the cables for the hydraulic brakes, they are very responsive!
09-22-2022, 12:49 PM | #8 |
It looks like a home made set up using a Borg Warner R10 tail shaft OD. There were kits made by several shops back in the day. They were generally a little cleaner set up but were still basically home made set ups.
This is a good link on the ones that used the electric function for operation. http://www.santaanitaas.org/wp-conte...r-Apr-2005.pdf This link to the HAMB illustrates how one of the kits looked back in the day. https://www.jalopyjournal.com/forum/...del-a.1064773/ |
09-22-2022, 01:11 PM | #9 |
I also believe it is a Borg Warner overdrive. From the photos it appears to have been one produced for Ford. The Ford overdrives had a long tunnel on the back section.
Tom Endy |
09-22-2022, 08:17 PM | #10 |
Hi swimmer, looks like a borg Warner type 30 used in ford's and other makes.i had one in a 29 Murray I drove thousands of miles. Bought out of Washington state. Those cables are for the emergency brakes. Your unit has been converted to mechanical with the solenoid removed. If you can't figure it out I can probably help you. I am in rockport.
09-23-2022, 10:31 AM | #11 |
First time I've heard of cables for hydraulic brakes, can you elaborate?
09-23-2022, 12:04 PM | #12 |
Cables are for the emergency brakes on the hydraulic setup.
09-23-2022, 12:24 PM | #13 |
Understood, but that's not what the OP said.
09-23-2022, 01:10 PM | #14 | |
Richard Knight, I might take you up on that offer. Would be good to connect with other antique ford owners in the area! |
