01-08-2022, 10:28 AM | #1 |
12volt or not?
My battery just died. Is now the time to think of 12v? Bearing in mind this is a 23,000 mile original paint & interior car and bone stock otherwise.
01-08-2022, 11:03 AM | #2 |
Re: 12volt or not?
It depends on if you want to keep your car "original" as Ford made it. If it's running fine on 6V keep it as it is. Converting to 12V will entail more than just changing the battery, as you know.
01-08-2022, 11:24 AM | #3 |
Re: 12volt or not?
When everything is the way it is supposed to be, 6 volts is just as good as 12. IMO, it would be a shame to change in your particular car. Of the 5 cars I have that run flatheads, only 1, the avatar roadster, uses 12v.
01-08-2022, 11:52 AM | #4 |
Re: 12volt or not?
Replace with an Optima 6v - good battery. I have had mine since 7/10. No problems and it has a lot punch.
01-08-2022, 12:13 PM | #5 |
Re: 12volt or not?
6V OPTIMA Time!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
01-08-2022, 12:38 PM | #6 |
Re: 12volt or not?
01-08-2022, 02:06 PM | #7 |
Re: 12volt or not?
6 volt Optima are available on Amazon. Get a good discount if you sign up for the credit card
01-08-2022, 02:16 PM | #8 |
Re: 12volt or not?
The car was designed for 6 V, it was built for 6 V, it operated for 60 + years just fine with 6 V.
If the car could actually vote and have a say in this discussion, I think it would prefer to stay the way it is. Everything is fine, new 6V (Optima) solves everything. Changing everything would be your idea, not the car. Also no logic in doing that. Looking at this another way, what would you think about having your grand kids deciding to uproot you and change everything in your life just because they wanted to. I don't think that would go over so good. Go out and ask the car what it wants. Simple. |
01-08-2022, 04:39 PM | #9 |
Re: 12volt or not?
these days there is no reason to change unlike years ago when 6v was rare Now there is just so much available it doesn't make sense
01-08-2022, 06:16 PM | #10 |
Re: 12volt or not?
Like all these answers
01-08-2022, 06:32 PM | #11 |
Re: 12volt or not?
Bone stock and original with good systems and just a bad battery. Yea I vote for getting the improved battery system, which I assume the battery mentioned is improved over a std 6 volt. Also If the wiring and all the systems worked prior to battery going south I sure would not plan to change. Changing to 12 volt requires a lot of things to be changed as mentioned.
Just two more pennies! Sounds like a awesome car you have we need more pictures too! Regards, Chris
1932 AAB Truck 1953 Ford Jubilee 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
01-08-2022, 09:17 PM | #12 |
Re: 12volt or not?
Get a good 6-volt battery. They mage a 550 CCA AGM 6 volt that looks pretty original
01-08-2022, 09:20 PM | #13 |
Re: 12volt or not?
Stay stock 6V. Go for an Optima red top.
01-09-2022, 02:27 PM | #14 |
Re: 12volt or not?
I looked on Amazon. $561. I don't think so. Advance Auto has them for $224 plus core charge. This is for Group 1. Don't Fords use Group 2?
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
01-09-2022, 02:34 PM | #15 |
Re: 12volt or not?
Jembow is in England.
01-10-2022, 02:10 PM | #16 |
Re: 12volt or not?
I considered converting my 1939 truck to 12 volt and finally decided that it worked back in 1939 so why change. Thus, I kept everything as stock as I possibly could. No regrets on doing that. When rebuilding the electrical wires, I soldered all connections. I kept the rebuilt generator and rebuilt coil and I haven't had any problems with starting. It does take more cranking after sitting through the winter, but once started, starts right up with 6 volt. Just my two cents.
I also wanted to share with fellow FordBarner's. I finally found a picture of my truck sitting in front of my parents house back in 1966?? Was truly a love to restore as it was the truck I learned to drive in. Hard to believe it has been 55+ years. A lot of the damage on the truck was the result of my brother. I remember my father putting snow in the bed in the winter to assist traction. I also remember sitting on the fenders around the headlights. Hope these pictures come through. Kind of a rookie in uploading pictures. 20201004_182708 (2).jpg |
01-10-2022, 02:16 PM | #17 |
Re: 12volt or not?
My followup picture.
01-10-2022, 02:18 PM | #18 |
Re: 12volt or not?
Apologies, I need to figure out why my picture of the truck today won't upload.
01-10-2022, 02:30 PM | #19 |
Re: 12volt or not?
Maybe this will come through.
01-10-2022, 04:10 PM | #20 |
Re: 12volt or not?
So, that's the SAME truck? If so, you done really GOOD! DD |
