Old 03-18-2020, 09:54 AM   #1
woofa.express
woofa.express's Avatar
Default replace wheels with steel wheels. help please.
Help requested please.
I am wanting to substitute steel wheels for my wire wheels on my 1930 Roadster.
Why you may well ask? To buy tyres for the original 17 inch wheels is expensive. Our AUD is very low and the exchange rate will cost the tyres at 250 to 400 AUD. Freight from USA is also a killer. So that is the reason; purely economics.
What will fit? Is anyone currently using them or has in the past?
I know many things,
But not everything,
At times I may not remember,
But there are things I do not forget.
woofa.express is offline   Reply With Quote
Old 03-18-2020, 10:02 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: replace wheels with steel wheels. help please.
Maybe measurements on original export vehicles were different but stateside, a 1930 Roadster originally came with 19" wheels and not 17".
In the states, a mid 1970s Ford pick-ups (-amongst a few others) used a 5 on 5½" lug pattern that used a 15" tire. Since I am unfamiliar with what is available down under, all I can suggest is look for something local to your area that uses that same lug pattern.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-18-2020, 03:31 PM   #3
woofa.express
yes Brent you are correct. 19 inch wheels. how silly of me. cheers, gary
I know many things,
But not everything,
Old 03-18-2020, 10:10 AM   #4
canadian
wheels from a 2001 Chevy tracker or a Suzuki samurai bolt directly on with no modification , I have used these this no issues. I have pictures but cant upload for some reason , I can send them to you by email if you want?
canadian is offline   Reply With Quote
Old 03-18-2020, 12:07 PM   #5
Jim Brierley
Several cars & trucks had the 5 on 51/2" bolt pattern, some Chrysler products & Jeeps, for instance. The problem is the A's have a step in the brake drum, most wheels are flat where they contact the drum. If you don't allow for this the wheels are not supported correctly and are likely to crack. wheel adapters are available for this, or you can fabricate a ring to replicate the A drum. Ford's 1940-48 are 16", Mercury & Lincoln '49-??? are 15". Some are wider than others.
Old 03-18-2020, 12:26 PM   #6
Aretino
Aretino's Avatar
A modern steel/ aluminum wheel conversion kit might be a great idea for the parts vendors to offer. Include wheels and adapters to allow for a modern radial tire.
Aretino is offline   Reply With Quote
Old 03-18-2020, 01:52 PM   #7
canadian
that is false, In the case of tracker and Suzuki wheels they fit and perform flawlessly.
Old 03-19-2020, 06:57 PM   #8
updraught
updraught's Avatar
I've read this several times and looked at the picture. Which bit is false?
updraught is offline   Reply With Quote
Old 03-19-2020, 07:55 PM   #9
canadian
if this is directed to me, it is stated by Jim who has been hands on since 1956 that you must use a spacer or ring to mount a 5.5 wheel, and nothing will work unless there is a spacer. false.
Old 03-19-2020, 08:29 PM   #10
TerryO
TerryO's Avatar
Not trying to take sides but it plainly says "most wheels". I don't see where it says "all wheels"... just saying...
TOB
TerryO is offline   Reply With Quote
Old 03-19-2020, 08:41 PM   #11
canadian
TOB
Terry, I am just suggesting for member who was asking for suggestions , after trying dodge, ford, jeep wheels I came up with rims suggested from another site, I was only offering a simple cheap solution. it is well know about the Model Hub. I am using a proven direct fit wheel which a fellow Model A Owner shared. my final post on this, I dont want to be Banned , I need the information shared here because I dont know everything and enjoy sharing what I have learned.
Old 03-18-2020, 05:29 PM   #12
Charlie Stephens
Here is an illustration of what Jim is talking about in Post #4. https://www.fordbarn.com/forum/showt...=1#post1286293
Be sure to read it, worst case the wheel may fall off.
Charlie Stephens
Old 03-18-2020, 06:04 PM   #13
canadian
B6D9DDCC-455C-426A-98A6-2E60A2DBEE52.jpg. these wheels from 2001 chev tracker, fit flush , the large centre hole in rim permits rim to mount flat/flush with drum. believe it or not.
Old 03-18-2020, 06:59 PM   #14
Randy in ca
Randy in ca's Avatar
Originally Posted by canadian View Post
Attachment 424729. these wheels from 2001 chev tracker, fit flush , the large centre hole in rim permits rim to mount flat/flush with drum. believe it or not.
Most solid wheels with the correct bolt pattern do not have a center hole large enough to fit over the raised ring present on Model A hubs without interference. Adapters used to be available to raise the rest of the hub/drum surface to that of the inner ring. Do these Chevy wheels have a large enough hole, or have you enlarged it?
Randy in ca is offline   Reply With Quote
Old 03-18-2020, 09:50 PM   #15
canadian
yes the rim I am using fits exactly outside that rim, no adapters,
Old 03-18-2020, 07:58 PM   #16
updraught
updraught's Avatar
Autotrader says:
"Although the Samurai is dead to the U.S. market, it lives on elsewhere in the world under names such as the Sierra, the Katana and the Jimny. Because Suzuki pulled the Samurai from the States in 1995, we missed out on the vehicle's first major update, including coil springs and a better interior. Suzuki still makes the Jimny to this day -- and while the current version dates from 1998, it's still a tough-as-nails mini off-roader. You can buy one in Japan, Australia and South America... but not here."
I was looking at a new hail damaged Jimney recently. That's the hail after the fires ... before the pandemic.
https://www.youtube.com/watch?v=Bs1P_wbGnA4
Old 03-19-2020, 09:00 AM   #17
V4F
V4F's Avatar
im running steel all around . got them new from Les Schaub . nice straight wheels , fit perfect .
V4f
V4F is offline   Reply With Quote
Old 03-19-2020, 11:29 AM   #18
PAracer
Canadian,
I zoomed into your picture but could not make out the tire size. Are these 15 or 16" rims? Do you happen to know the rim with and backspacing?
Thanks,
Mike
PAracer is offline   Reply With Quote
Old 03-19-2020, 05:55 PM   #19
canadian
Originally Posted by PAracer View Post
Canadian,
Thanks,
Mike
15 inch, P205/70R/15. Not sure on rim width or backspacing. I needed rims for storage and after trying several these were suggested from a Face Book Model A site. I am well aware of the drum design with raised ridge, these wheels have a large centre by design. these fit flush . I offered this as a suggestion to a member who was looking for alternative , these are not for the purist . these rims are from a Canadian Chevrolet tracker, exact same as Suzuki Samurai , 2001. all the other 5 x5.5 rims I tried would not clear centre and were not touching drum. and again this was supposed to try and help someone out, if they didn't fit safely I wouldn't suggest.
Old 03-19-2020, 11:38 AM   #20
Jim Brierley
canadian, so maybe my post was actually true! I've been playing with performance A's since 1956, and I have learned a thing or two.
