04-30-2018, 11:45 PM | #1 |
model a rear to '33 ford trans
first things first. i am going to build a gow job one of these days. i have a t body and turtle deck, grille, frame, front axle, and a '33 ford flathead motor and trans. i also have the rear end. it is in sad shape. i have a '30 ford rear in good shape. now after all this diatribe my question. will the model a drive shaft and torque tube bolt up to the '33 trans?
05-01-2018, 12:07 AM | #2 |
Re: model a rear to '33 ford trans
you need to cut off the 6 bolt flange on the bell for the a trans, and get a later v8 4 bolt / 2 piece flange for the back of the trans. drive shaft is the same, u joint fits if the length is correct for what you are building
05-01-2018, 10:12 PM | #3 |
thanks for the reply but i think you missed what i wrote. it is a '33 motor and trans to a model a rear end.
05-02-2018, 01:22 AM | #4 |
you just have to use the "clamshell " to match the transmission, the bell is the same curve, the driveshaft splines the same, the u-joint interchanges
05-02-2018, 08:35 AM | #5 |
All you need are the two V8 clamshell pieces shown below, with FOUR mount holes. The Model A trans is shown so you can see the difference. It's a "bolt-on" swap. DD
V8 clamshell pieces: Model A trans below: |
05-02-2018, 07:40 PM | #6 |
