Old 10-23-2017, 09:06 AM   #1
len
Default Oil pan
Is it possible to remove the oil pan on a 292 in a 56 Victoria
with out removing the engine from the car? Thanks Len
len is offline   Reply With Quote
Old 10-23-2017, 10:07 AM   #2
Bleach
Bleach's Avatar
Default Re: Oil pan
See below, these guys know better.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Bleach is offline   Reply With Quote
Old 10-23-2017, 11:06 AM   #3
42merc
42merc's Avatar
Default Re: Oil pan
The oil pan can be removed while the engine is in the car.
As a youngster I did a lot of engine work on '54-'57 Fords. Rings, rod bearings & cam changes without removing the engine.
42merc is offline   Reply With Quote
Old 10-23-2017, 11:52 AM   #4
Dobie Gillis
Dobie Gillis's Avatar
Default Re: Oil pan
Rotate the crank so that the front throw is up out of the way, then you can noodle it out.
Dobie Gillis is offline   Reply With Quote
Old 10-24-2017, 11:03 AM   #5
Ole Don
Ole Don's Avatar
Default Re: Oil pan
In a Y block, the crankshaft is always up out of the way. In a flathead, the above is true.
Ole Don is offline   Reply With Quote
Old 10-24-2017, 02:44 PM   #6
JeffB2
JeffB2's Avatar
Default Re: Oil pan
Back when I did it I dropped the idler arm for clearance but that was 40 years ago.
JeffB2 is offline   Reply With Quote
Old 10-24-2017, 04:01 PM   #7
packrat5
Default Re: Oil pan
like dobie says, ROTATE THE CRANK UNTIL IT CLEARS
packrat5 is offline   Reply With Quote
Old 10-24-2017, 06:41 PM   #8
Bleach
Bleach's Avatar
Default Re: Oil pan
I read on a 57 you need to set the crank to #1 on TDC. Maybe will work fine for a 56.
Old 10-25-2017, 05:36 AM   #9
LOWRIDER
LOWRIDER's Avatar
Default Re: Oil pan
Won't work on a 57 but it will on a 56. I've owned both.
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 10-25-2017, 09:59 AM   #10
Bleach
Bleach's Avatar
Default Re: Oil pan
Hmm, I found the article on y-blocksforever that talked about replacing a rear main seal that involved removing the oil pan and the subject was a 57.
http://www.y-blocksforever.com/tech/...emainseal.html
Since you owned both, I can't knock that but why would they keep something that's wrong in their articles section.
Old 10-25-2017, 12:27 PM   #11
packrat5
Default Re: Oil pan
It's been many years since I worked on these engines on a regular basis, but for the sake of moving on, here goes. Contrary to what the general consensus is, all the y-block chassis were not the same, regardless of the engine being the same. First, ALL OF THEM REQUIRED ROTATING THE CRANKSHAFT to some degree or other. SOME required removing the starter. SOME required raising the engine slightly. And SOME required removing the sway bar.
As far as printed material being the sacred gospel truth, think again. And as for getting info from the internet, believe very little of it, as much of it is hearsay or "rumored" to be factual. I can't believe how some of this stuff just drags on and on and here I am getting sucked into the middle of it. When will I learn?
Old 10-25-2017, 02:48 PM   #12
Dobie Gillis
Default Re: Oil pan
Old 10-25-2017, 03:02 PM   #13
42merc
42merc's Avatar
Default Re: Oil pan
Most of us agree the pan can be removed with the engine in the car.
Like Packrat said, use your head, think it out--it's NOT a big deal.
Old 10-31-2017, 10:23 AM   #14
bobss396
bobss396's Avatar
Default Re: Oil pan
I helped someone do the pan on a '58 with a 312 or 292 years back. It can be done.
bobss396 is offline   Reply With Quote
Old 10-31-2017, 11:49 AM   #15
scicala
scicala's Avatar
Default Re: Oil pan
I hope the suction didn't hurt.
Sal
scicala is offline   Reply With Quote
Old 11-02-2017, 06:21 PM   #16
len
Default Re: Oil pan
I should have added the car has power steering would that create extra problems?
Old 11-02-2017, 07:33 PM   #17
packrat5
Default Re: Oil pan
Lenny, Lenny, Lenny, have you not been paying attention? Crawl under the car and look. Figure it out. And PLEASE don't ask what kind of tools you will need next.
Old 11-03-2017, 02:22 PM   #18
len
Default Re: Oil pan
I did not realize that was a stupid question for the experts on this Forum.
Old 11-03-2017, 03:59 PM   #19
scicala
scicala's Avatar
Default Re: Oil pan
No question here is stupid Len. Some people have a short fuse.
Sal
Old 11-03-2017, 07:39 PM   #20
packrat5
Default Re: Oil pan
It's not about a short fuse, it's about a short patience tolerance. There is no animosity intended. Need I apologize again?
