I got a box of cut outs on ebay. One of them turned out to be a voltage regulator. Anyone know a way to tell if it is 6v+ or 12v-?
If it has only one component under the cover, then it's the diode type of cutout and not a regulator.
If it has a bunch of components under the cover the a call to "Fun Projects" is in order as they are the only ones that make that type.
I would see what happens when you put a 6v battery charger across it. The 6v battery charger is probably putting about about 7.5 or 8 v so should trigger a 6v regulator, but not a 12 v one- assuming of course that the regulator is actually functioning correctly!
If'n it's a Fun Projects regulator the cover will be welded on.
#5 | |
![]() Quote:
#8 | |
![]() Quote:
