Old 05-25-2015, 02:13 PM   #1
Walt Ebie
Walt Ebie's Avatar
Default Backfire and Die
2 weeks ago: Out for a drive....started some jumps and jerks...a few backfires. I stopped and in a few moments it smoothed out and I got home.
Yesterday: Out for another drive.....started the jumping and backfiring again but more serious....finally died and would not start. I came home on the hook. I pulled the plugs today - they were a little carboned up but not really too dirty; checked the gap and put them back in. So what's next? Did it slip the timing? Maybe a bad carburetor float? What say ye? By the way, this is a '30 coupe. Walt
Walt Ebie is offline   Reply With Quote
Old 05-25-2015, 02:32 PM   #2
Mitch//pa
Default Re: Backfire and Die
check for the basics spark and fuel. then attack
Old 05-25-2015, 03:04 PM   #3
Patrick L.
Patrick L.'s Avatar
Like Mitch said, check for spark and fuel and let us know which it is. Check to see if the rotor turns. It also makes a difference as to how it was backfiring and quit.
Old 05-25-2015, 03:19 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Clean the points, carefully, with FINE grit paper & check the gap. This is the most common cause of runnin' piss poor!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-25-2015, 03:58 PM   #5
barkleydave
barkleydave's Avatar
Same as mentioned above also... (my glitch a few weeks ago)
Bad Fuel... fuel was not old just a bad load in a gas tank.
How old is the fuel in your tank?
Missed sputtered no power and back fires when pushed a little.
barkleydave is offline   Reply With Quote
Old 05-25-2015, 04:35 PM   #6
WestCoast
ok, when it dies pull coil wire and see if there is spark, if so look down carb and work the accelerator shaft to see if any fuel is squirted down carb throat, is it back firing out the carb or tail pipe?, does the coil get to hot to hold with your hand?, if so good chance its bad ,if you really want to get into it, plug fuel line from fuel pump to carb, hook up a gallon fuel can with a hose from it to the carb, see if it runs ok that way, if so fuel problem, if not probably an electrical problem, as was stated, do what he said, do all the easy things first, don't out smart your self
WestCoast is offline   Reply With Quote
Old 05-25-2015, 04:40 PM   #7
Mitch//pa
Originally Posted by WestCoast View Post
ok, when it dies pull coil wire and see if there is spark, if so look down carb and work the accelerator shaft to see if any fuel is squirted down carb throat, is it back firing out the carb or tail pipe?, does the coil get to hot to hold with your hand? if you really want to get into it, plug fuel line from fuel pump to carb, hook up a gallon fuel can with a hose from it to the carb, see if it runs ok that way, if so fuel problem, if not probably an electrical problem, as was stated, do what he said, do all the easy things first, don't out smart your self
i think your doing this person a disservice sending him on a wild goose chase
from what i read we are working on an originally equipped model A
Old 05-25-2015, 04:48 PM   #8
WestCoast
how so, hes having engine running problems, ive just gave him a few places to start, should I just told him it cant be fixed and just forget it?
Old 05-25-2015, 04:51 PM   #9
Mitch//pa
a stock ford model A does not have an accelerator pump or a fuel pump. i have had a little to drink today but not that much
Old 05-25-2015, 04:56 PM   #10
WestCoast
opps, sorry wrong forum, should have been in the flathead room, haven't drank it 50 years, so I cant use that as an excuse
Old 05-25-2015, 07:49 PM   #11
Mitch//pa
whhheeww u had me worried
Old 05-26-2015, 12:02 AM   #12
CA Victoria
CA Victoria's Avatar
I read the title.....my first thought was that happens to me too when I have to much fiber! But then he was talking carburetors ..........
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 05-26-2015, 05:20 AM   #13
Jacksonlll
Jacksonlll's Avatar
If your plugs were black and fuzzy, be sure to scrape out the carbon in the annulus. sp?
If you did, did it run good after you cleaned them. Could try a splash of water on the carb bowl next time it happens.
Old 05-26-2015, 05:59 AM   #14
theHIGHLANDER
Nobody mentioned the condenser. Spark 1st, then fuel. If all's well in those 2 departments it might call for digging deeper. Someone said look to see if the rotor turns. Once in a blue moon the distributor pin can shear, but keep it simple 1st.
theHIGHLANDER is offline   Reply With Quote
Old 06-02-2015, 06:47 PM   #15
Walt Ebie
Walt Ebie's Avatar
Thanks for your help...had some trouble trying to log in for several days. Meanwhile, buffing up the points, checking the gap, cleaning and checking the plugs AND a condenser seems to have got her going again. Thanks to you all!
