Old 04-05-2015, 12:52 PM   #1
Brianfrench65
Brianfrench65's Avatar
Default 30 - 31 instrument panel
My old instrument panel has the reveals (above fuel gage, and below speedometer) painted gloss black. Is it correct to paint these, or leave them chrome?
Last edited by Brianfrench65; 04-05-2015 at 05:59 PM. Reason: Incorrect terminology
Brianfrench65 is offline   Reply With Quote
Old 04-05-2015, 01:35 PM   #2
Roger V
Roger V's Avatar
Default Re: 30 - 31 dash
Not being picky but those are instrument panels whereas the dash is the rail that goes from post to post. It just makes it clearer when discussing it. My understanding is the recesses should be satin black but any kind of black will be ok unless showing in fine point.
Roger V is offline   Reply With Quote
Old 04-05-2015, 02:15 PM   #3
Brianfrench65
Thank you, and I will refer to it correctly in the future, I am learning.
I really appreciate the Wisdom of the members, it certainly helps those like me.
Old 04-05-2015, 02:38 PM   #4
Bob C
If that is a reproduction instrument panel I would make sure all
the screw holes line up before you get to carried away.
Bob
Old 04-05-2015, 03:18 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
painted.
Old 04-05-2015, 06:39 PM   #6
armchair67
Default Re: 30 - 31 instrument panel
Not trying to hijack this thread, but the instrument panel on my 31 Tudor is not a polished chrome, more of a dull finish and it has grooves that run horizontally top to bottom. Is this correct? Most of the ones I've seem in photos are smooth , with bright chrome finish.
armchair67 is offline   Reply With Quote
Old 04-05-2015, 06:46 PM   #7
Mitch//pa
yes thats correct
it should also be painted black in the areas shown on post 1 top
Old 04-05-2015, 06:49 PM   #8
Roger V
Roger V's Avatar
Yours is correct for a mid-'30 to end of production in '31. The smooth instrument panels are for '28 to mid'30 with the oval speedometer. The original plating was either bright nickel or butler finish nickel which is duller. The repros are chrome plated as well as some originals that were replated with chrome instead of the nickel plating. For a driver some don't care or just want chrome which doesn't deteriorate like nickel.
Old 04-05-2015, 08:03 PM   #9
CarlG
CarlG's Avatar
Very often Don Turley has original restored instrument panels that are correctly nickle plated on the swap meet. Nothing like having an original that fits correctly!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-05-2015, 08:36 PM   #10
SkipShift
SkipShift's Avatar
My neighbor replaced this terrific original instrument panel with a new chrome one. He couldn't get the screws on the new one started so I installed it for him. Now I own the car and the old Instrument panel is nowhere to be found.
SkipShift is offline   Reply With Quote
Old 04-05-2015, 10:49 PM   #11
Mike V. Florida
Chrome means one of two things, improper restoration or reproduction. The originals were nickle plated.
Old 05-07-2015, 11:11 PM   #12
Mike V. Florida
Don, Did the later '31's come in brass or just the ones without the outline?
Old 05-08-2015, 10:43 AM   #13
burner31
burner31's Avatar
Here is an original '31 dash, the amp meter is new.
Keith
Shawnee OK
'31 SW 160-B
