Old 01-27-2015, 05:19 PM   #1
Brian T
Brian T's Avatar
Default Welch plug
I am in need of the welch plugs that fit tillotson carburetors, I know they are 3/8 inch, is the plug that fits the rear main cap the same size?.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 01-27-2015, 09:02 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Welch plug
The best that I remember, the welch plug that fits the rear main bearing cap is 7/16 . NAPA can get the welch plugs, it took about a week to get them for me , the last time . Take the carburetor with you. If the parts store has an older parts man you will be lucky. The younger counter guys don't know what a welch plug is .
Old 01-28-2015, 12:30 PM   #3
Res731
Res731's Avatar
Some of the model A vendors carry them too - I got some for mine but haven't replaced them yet.
Res731 is offline   Reply With Quote
Old 01-28-2015, 01:07 PM   #4
Purdy Swoft
Thats good!!! If you don't mind, Which model A vendors handle the welch plugs ?
Old 01-28-2015, 01:17 PM   #5
Brian T
Brian T's Avatar
Thanks you all,
The reason I asked was Snyders now carry the plug for the rear main cap, I was hoping it would be the same size as I have to order some parts from them, ---- Purdy there is nothing wrong with your memory 7/16 it is, the Ford #74108-S in the price list.
Sacramento Vintage have them but I do not buy from them I will go to Oreillyauto with the print out, saves time describing want you want.
Thanks again Brian.
Old 01-28-2015, 01:23 PM   #6
Res731
Res731's Avatar
I saw them at Sacramento Vintage as Brian posted.
Old 01-28-2015, 04:26 PM   #7
Purdy Swoft
Thanks Brian T and Res 731 . Welch plugs aren't always easy to obtain quickly. This will help others as well. I haven't yet bought from Sacramento Vintage but I know that Snyders is a lot quicker than NAPA for model A stuff and much less expensive as well .
Old 01-28-2015, 04:46 PM   #8
Brian T
Brian T's Avatar
I am picking the welch plugs up this afternoon, my local store found me 4, always take a printout of what you need if possible, I do not understand why the venders that sell Tillotson parts do not supply them, they need to be in the kits, behind that plug could be a dirt trap there are 2 tiny passages that may cause problems.
Old 01-29-2015, 11:20 PM   #9
Purdy Swoft
I don't see a 7/16 welch plug for the rear main bearing cap in my Snyders catalog. Maybe this part is only offered on line ?
Old 01-30-2015, 12:26 AM   #10
Brian T
Brian T's Avatar
Purdy, it is a new item that's just been added.
http://www.snydersantiqueauto.com/se...?page=3&q=plug
Old 01-30-2015, 11:27 AM   #11
Purdy Swoft
Thanks Brian for the link !!! I copied the part number in my notes . The part will probably be listed when the new 2015 catalog comes out. Thanks again for your help and time .
