09-03-2014, 06:39 PM | #1 |
59 ford steering gear box
bobss396
thanks for the info on the gear box, ithink i can change the gasket on top of the box,but i was hoping i could change the one on the bottom without removing the whole gear box. just bought this skyliner,so i guess the fun begins! |
09-03-2014, 07:36 PM | #2 |
Re: 59 ford steering gear box
The gaskets are actually a shim pack that control the worm bearing preload so if your steering isn't sloppy or too tight be sure to go back with the same thickness of shims or unhappiness may result.
09-04-2014, 03:00 PM | #3 |
thanks for the info on the 59 steering box,i hope i dont have to go that far into it thanks again bsky59 |
