With the clutch bolted in place, disc as well, should there be any side to side or up and down movement in the transmission input shaft when inserted into the clutch/flywheel??
We have been trying to solve a transmission problem on a 1930 Chevrolet truck 3 speed. When I inserted another input shaft, I have movement in both directions. Several information sources indicate this could be a cause of a transmission jumping out of third gear, our problem when the engine is under a load or pulling. The pilot bearing should keep the shaft straight and true?? Thanks!!
Bob from Northport Northport, Michigan |
maybe the front bearing in the transmission is bad .
V4f |
the pilot bearing and front trans bearing should hold the input steady with no lateral movement. if your trying it with a dummy shaft not installed in the trans you will get back end movement as no bearing is holding it.
the pilot bearing and the front bearing in the tranny keep the input shaft properly supported and aligned on each end. Check both for slop and wear, and check the machined stub on the very front of the input shaft for wear (the part that engages the pilot bearing.
Check to be sure the bell housing and tranny bolts are tight. The front of the output shaft rides in a recess in the input shaft and also on the rear bearing, check those places for wear be sure the shifter detent springs and balls are tight and round. All tranny parts need to be within spec, they all help to keep it in gear
'31 180A |
Is there a pilot bearing installed ?? If so, is it worn (they do wear)?? Is it the original engine and trans?? Did this problem just start??
Paul in CT |
I keep a new pilot bearing handy and use it to check the fit on the nose of the shaft whenever rebuilding a transmission. The input shaft can be repaired by machining the nose down and pressing a sleeve over it. Tom Endy |
I always replace the pilot bearing when the flywheel is out.
