Old 08-26-2010, 02:38 PM   #1
nick c
Default 29 cc pu door glass
Could someone please explain to me the correct way to install door glass in my door. I dont believe it will go through the hole in the bottom, so it must go in the top. I bought the expensive felt channel kit from Mikes. I need to know the proper procedure to install the felt channel and the glass.
thanks nick
nick c is offline   Reply With Quote
Old 08-26-2010, 05:22 PM   #2
JTW
JTW's Avatar
Default Re: 29 cc pu door glass
The trim, around window on the inside of the door, slides up and off as a unit. Put the fluid to it as sometimes they are rusted on - tap lightly with a mallet and block of soft wood. You then should have the room that you need.
JTW is offline   Reply With Quote
Old 08-27-2010, 05:45 AM   #3
Steve from PA
Steve from PA's Avatar
After you remove the frame with rthe glass 3/4 of the way up the glass and the felt tracks will be able to be tilted in enough so the glass slides up and out.
Steve from PA is offline   Reply With Quote
Old 08-27-2010, 06:50 AM   #4
nick c
At the top of the door where the foam rubber gets glued on, there is no metal in the corners to glue to, is there supposed to be a piece of channel that goes across and covers the open corners?
