Is there any logical reason someone would toe-out a Model A 1/4"?
I corrected it to be 1/8" toe-in but got to wondering if someone had a reason to do this. (I have not road tested the car yet since adjusting the toe). The car did handle a little squirrely toed out, but not too bad. She does have a lot of slop in a kingpin and I got to wondering if this was someone's trick to compensate for that play. Appreciate any thoughts. |
Correct toe-in is about 1/32-1/16th inch. Toe-out will cause premature tire wear and bad handling.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
Maybe for a more exciting ride?
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup 1931 Coupe 2 Smith Motor Compressors 1951 Ford F1 High Desert Model A's |
The only logical reason is they didnt know any better. I bought a Jeep for my wife and the toe was 1 1/4" out. You want to talk about an exciting ride.
Thanks - it did make it interesting hitting bumps. Exciting is a good word - just never sure which way she was going to try and go next
You will need to take of any worn axle and steering linkage parts before adjusting toe in, toe in is the very last adjustment done to any front end.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
Mine was set at 3/4" toe-in. Wiped out the front tires in about 1500 miles.
#9 | |
![]() Quote:
Adjusted the toe in just to make it a little more stable for now, but the king pin slop will still be with me. |
