Old 04-20-2015, 08:00 AM   #1
Zack
Zack's Avatar
Default emergency brake shaft brace
I was installing the emergency brake shaft this weekend and I don't know if I have the the brace installed correctly. Can anyone tell me if I have it right or wrong? After all the pictures I took, I guess I must have missed this one..
Thanks,
Zack
Zack is offline   Reply With Quote
Old 04-20-2015, 09:24 AM   #2
jw hash
jw hash's Avatar
Default Re: emergency brake shaft brace
you have the brace in right, I can`t quite make out the bolts, the nuts and lock washers go the rear.
jw hash is offline   Reply With Quote
Old 04-20-2015, 12:17 PM   #3
Zack
Zack's Avatar
Thanks for the response. I have the nuts inside the cross member facing forward. I'll fix that. I wasn't sure if I had the brace mounted correctly.
Old 04-20-2015, 12:24 PM   #4
rocket1
I don't remember seeing a brace on my pickup,does it just rest against the cross shaft?I could fabricate one,does anyone have the measurements? thanks in advance.
rocket1 is offline   Reply With Quote
