02-02-2018, 11:35 PM | #1 |
Panel light switch for 36 coupe
Does anyone know if the vendors make a repo of the dash panel light switch ?
Or where could I get an original one ?? The tabs that hold the panel light switch into the dash are broken off. Any suggestions ? |
02-03-2018, 07:21 AM | #2 |
Re: Panel light switch for 36 coupe
They are not remade. The 35 works differently than the 36 or the 37 (same except the knob). May try a couple small dabs of RTV to secure the switch to the dash. Used originals often do not work but sometimes inserting a piece of plastic between the two electrical terminals will restore operation.
02-03-2018, 07:34 AM | #3 |
They are not reproduced and hard to find.They do turn up on EBAY occasionally .Might help to post an ad on this site or the V8 club site.
02-03-2018, 01:37 PM | #4 |
Thanks to all...
02-03-2018, 01:45 PM | #5 |
If yours only has the tabs broken off you might try to find a way to repair it.
02-03-2018, 01:54 PM | #6 |
02-03-2018, 06:43 PM | #7 |
I have a 200 Joule laser welder and I can repair it with new tabs.
John |
02-03-2018, 08:48 PM | #8 |
John...I never thought of using a lazer welder...my son has one...thanks
02-03-2018, 09:01 PM | #9 |
Really? Very pricey for a welder. What do you use it for?
41 woodie https://41fordwoodie.weebly.com/ |
02-04-2018, 09:44 AM | #10 |
Laser welders are used in the dental industry, jewelry industry, aero-space, etc. they will weld almost anything on a small scale. Superb on stainless steel.
John |
02-04-2018, 02:32 PM | #11 |
I have a similar problem in a 37 Ford Woody Wagon... the instrument light switch/dimmer on the dash sometimes gets very hot and starts to smoke... NOT GOOD! Haven't been able to find a replacement switch anywhere. I would really appreciate some suggestions - either how to repair this one, where to find a replacement switch, or an alternative solution.
Photo attached. THANKS! Bill |
02-04-2018, 03:01 PM | #12 | |
02-04-2018, 04:57 PM | #13 |
kuipers: Looks like an original dash light switch which is not a dimmer. Most likely gets hot due to poor electrical contacts inside the switch. Try the suggestion I made above.
02-05-2018, 08:40 AM | #14 |
Thanks for everyones suggestions......
02-05-2018, 05:10 PM | #15 |
Why would anybody want to turn their dash lights off. If your switch doesn't work just bypass it.Mine worked when i installed it 20 years ago but i haven't had a reason to try it Lately so it might not work now
02-06-2018, 12:43 PM | #16 |
The original dash light switch on the '36 Ford is not a dimmer, it is off/on only.
If you have ever driven a 'thirty model" Ford on the open highway at night, you will appreciate the off/on feature of the dash lights, the glare from the dash lights can be very annoying.
Bill.... 36 5 win cpe |
