03-20-2018, 03:47 PM | #1 |
'32 3-W Rear Window
What is the best rear window seal for a '32 3-W roll down rear window, and who has it? Thanks
03-20-2018, 07:36 PM | #2 |
Re: '32 3-W Rear Window
There is not really much of a seal, it is similar to a side-glass. There is a drip-pan that catches the water that gets around the glass and drains out a tube through the floor in the trunk area. Are you looking for the whiskers?
https://www.fordbarn.com/forum/showthread.php?t=51176 Last edited by JSeery; 03-20-2018 at 07:50 PM. |
03-20-2018, 08:17 PM | #3 | |
03-20-2018, 08:40 PM | #4 |
Here is a link to the Carpenter kit, but I really don't know who sells the best kits.
http://dennis-carpenter.com/rear-win...kit/p/A-46108/ |
03-21-2018, 02:49 PM | #5 |
Drakes kit shows the rubber bumpers and it uses a single continuous piece of flexible channel. I think that would seal better than the rubber upper piece in the Carpenter kit
03-21-2018, 04:37 PM | #6 | |
What type of seal, if any, is being used at the Rear Glass Lower Metal Channel? Thanks |
03-21-2018, 07:24 PM | #7 | |
03-22-2018, 06:40 AM | #8 | |
03-22-2018, 07:40 AM | #9 |
The rubber channel with the lip is used on all door and coupe rear windows to set the glass into the horizontal steel window channel with the lip facing outward. It is normally sold separately and not a part of the kits that address the sides and top of the glass.
As for the upper soft rubber seal in the Vintique kit, it has a shallow U shape and provides an excellent seal when the upper edge of the glass is nested in the upside down U. |
