02-22-2013, 04:10 PM | #1 |
Early Mustangs
Does all of the 1964 1/2 - 66 Mustang convertibles have the extra frame reinforcement just about at the rear of the transmission? I am looking at a 66 that doesn't have the reinforced frame piece that goes from side to side at that point. Jim
The photo shows the piece I am talking about. Last edited by JimOH; 02-22-2013 at 04:15 PM. |
02-22-2013, 08:05 PM | #2 |
Re: Early Mustangs
You should get on a Mustang forum for this. My father-in-law had a 66 Coupe that had the whole underside restored to original and I don't remember his having the flat brace from side to side.
02-22-2013, 09:51 PM | #3 |
Re: Early Mustangs
Coupes didn't have them . Convertibles were supposed to, possibly the early ones didn't have it but they should have.. That bracing helps make up some of the body stiffness it loses when the metal roofs aren't there.
02-22-2013, 11:18 PM | #4 |
Re: Early Mustangs
Thanks guys,
I have been looking through some of the more than 100 64 1/2 - 66 Mustang web sites and I have come to the conclusion like mentioned above that all convertibles should have this bracing. I read an article that says all 64-66 convertibles had extra bracing and I suppose this is what they are talking about. Maybe later Mustangs do too. I see a lot of restored Mustangs don't have it. I have ordered the book, Collectorr's Original Guide, MUSTANG 1964 1/2-1966 by Colin Date. I should learn a lot from that. Thanks again, JimOH |
02-23-2013, 07:03 AM | #5 |
Re: Early Mustangs
In the early 70s I had a '65 convertible 289/4speed. I'm pretty sure it had that support because I had to remove the driveshaft. Can't remember if I had to remove the support (seems we did), or if we fished the shaft over it.
02-23-2013, 09:31 AM | #6 |
Re: Early Mustangs
All convertibles if I remember correctly had the connecting plate under the cars and were also equipped with inner rockers. Just a few of the things you will find on a convertible that you won't find on a coupe. Dave |
02-23-2013, 09:46 AM | #7 |
Re: Early Mustangs
Re read your post JimOH, There may be a couple of reason it is not there.
1-May have been left off...... 2- Car was restored and the car was not gap correctly and the pan will not fit now. 3- Car is original and without that in there it is sagging. Is the car restored? If so, by who? I restored Mustang here in Michigan in the 90's for Mid Michigan Mustang. If you have any question, feel free to ask. Dave |
02-23-2013, 10:34 AM | #8 |
Re: Early Mustangs
Is the mustang a unibody, looks it? I did not know that. My 1954 has a huge X frame added to the stock frame to stiffen it like all convertibles. This mustang would probably be real sloppy with out a frame and that extra support. One drive will tell you. One time I owned a Camero with a sun roof. Removing it made the body shake so bad that I seldom did it.
02-23-2013, 10:56 AM | #9 |
Re: Early Mustangs
Wow! Thanks a million to all of you. I had a '40 Ford convertible that had an extra plate on the bottom of the X frame. Ford must have carried this all of the way up.
I am learning from you all. JimOH |
02-23-2013, 11:14 AM | #10 |
Re: Early Mustangs
02-23-2013, 05:51 PM | #11 |
Re: Early Mustangs
