10-08-2022, 07:03 AM | #1 |
gas (fuel) canister, period correct
Hi Barners,
i did a 100 mile trip on friday again and after nearly running out of fuel (again), a thought crossed my mind. I would like some spare fuel on my Fordor slant windshield, but not a plastic one and none, that i have to keep in front of my back seats. I would a canister outside of the car, but it has to look like it was made for it. I know that there are canisters for Model Ts, which live on the running boards, but i don't think those are okay for an A... Any ideas, suggestions or hints? |
10-08-2022, 08:25 AM | #2 |
Re: gas (fuel) canister, period correct
What's causing you to run out of fuel in 100 miles? Are you 'sticking' the tank or reading the gauge? A 31 tank has 11 U.S. gallon capacity.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
10-08-2022, 09:40 AM | #3 | |
I know. What's causing me to nearly run out of fuel? I am drivin' my A, the weather is fantastic, the road is sweet, the countrysite beautiful... I am enjoying live! |
10-08-2022, 10:33 AM | #4 |
At least this one would look nice. 20 liters.
10-08-2022, 02:11 PM | #5 |
Never saw that before. 12x18.6x18.6 will fit on running board. A little pricey but it was built for gas and made of stainless.
https://www.sportsmansguide.com/prod...926f363b6f5d10 |
10-08-2022, 06:54 PM | #6 |
See https://www.tanksinc.com/index.cfm/p...rod/prd117.htm You should get at least 16 mpg (160 miles on a tank full) with your Model A. A higher compression head will help. The ignition timing and carburetor setting have to be right. It also depends on how you drive and what your finial rear end ratio is.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 10-08-2022 at 07:01 PM. |
10-09-2022, 11:08 AM | #7 |
Thanks, guys and gals.
Those saddle tanks look nice, but i want to keep my brakes more or less original, so they are out... And the military style gas canisters are great, but where do you put them? On the running boards, but you lose one door, don't you? I get around 13mpg but i am nowhere finished. Ignition/Distributor is on the list, the overhauled carburettor is also on the list. The list is still very long... I only own her since january... |
10-09-2022, 12:05 PM | #8 |
The one shown in post #4 is also available in 10 litre size. Maybe you can find similar locally?
https://www.amazon.ca/Stainless-Petr...012081918&th=1
10-09-2022, 12:42 PM | #9 | |
This is a nice one and shipping to germany is 'only' 20 $Can. It may fit, although not period correct... |
10-09-2022, 12:55 PM | #10 |
I have thought of hiding a tank in the trunk or under the car. Then use an electric fuel pump to refill the cowl tank while driving.
I remember seeing a vintage gas, water, oil can holder that looked like a tool box mounted to a running board. I thought it would be a good product today with metal box and plastic containers. |
10-09-2022, 02:20 PM | #11 |
If you are looking to keep it era, then you need a "Boyco Service Unit" to clamp to your running board. Here is an era flier showing what was available for the Ford Model A:
Note that some of them were made with a specific height so that the doors would clear them when opened. Brad in Maryland Last edited by Brad in Germany; 10-09-2022 at 10:26 PM. |
10-09-2022, 04:03 PM | #12 |
Service units and individual cans for running boards use to be fairly common
on eBay. I collected more then a few years ago off the ..'Bay. Take a look you might find something. Bob-A "Skirts are for Women, not Car Fenders" |
10-09-2022, 05:04 PM | #13 |
So hab' ich's gemacht:
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
10-09-2022, 08:14 PM | #14 |
You need some friends in New Zealand. This running board can & holder is very common down there.
10-10-2022, 04:29 AM | #15 |
Here's mine in a 31 Tudor. Out of the way of the doors.
SAJ in NZ |
10-10-2022, 06:58 AM | #16 |
This looks like a neat idea. I don't want the box on the rear of the car because i think it destroys the perfect lines of the car (edsel will be rotating in his grave) but i could make myself some fasteners on the rear bumper mountings for a canister. Food for thought... |
10-10-2022, 08:23 AM | #17 |
When I cleaned out my dad's garage I came across a new one of these.
10-11-2022, 01:12 AM | #18 |
10-12-2022, 05:17 AM | #19 |
Tach zusammen,
everything via Ebay. Canister from USA, the original stickers are from Australia.
