05-19-2016, 03:21 PM | #1 |
Drive shaft removal
Hi Gents-
I'm having trouble removing the pin in the drive shaft where it connects with the banjo assembly. This is a '48 Ford with the torque tube. Are these tough to remove? Thanks, R Sullivan |
05-19-2016, 04:00 PM | #2 |
Re: Drive shaft removal
Not usually all that difficult to remove unless the pin has wear steps caused by excessive spline movement. I just, maybe 10 min. ago, removed one on a '35-'36 tubular driveshaft and 10 spline pinion. Working on the end of the pin that had been peened, I determined the approximate center of pin and did a small center punch mark. Started drilling a hole ~ 3/32" dia. X ~ 1/8" deep. Then went to a ~ 5/32" drill bit and made the hole wider to the 1/8" depth. Keeping these holes on center of pin is critical. Then went to a punch that fit loosely in that hole, and using a medium weight hammer, I drove the pin out with a couple good wacks.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 05-20-2016 at 12:51 PM. |
05-19-2016, 04:14 PM | #3 |
John-
Thanks, Good explanation- I'll have this thing apart in no time. Maybe. |
05-19-2016, 09:54 PM | #4 |
