01-16-2021, 04:16 PM | #1 |
Sealed beam foglights wanted.
Hi, I have a question.
I have two Per Lux 200T FOG LIGHTS with 12V bulbs. Are sealed beam lamps in 6 volts available for these foglights? If so, maybe someone can tell me where I could order this (from here in Germany ...)? The outside diameter of the light inserts is 140mm. I'm only looking for FOG LIGHTS! Greetings from Berlin Andy |
01-16-2021, 06:00 PM | #2 |
Re: Sealed beam foglights wanted.
Clear or yellow/amber color?
If the internet converted 140 mm to inches correctly for me (5.511 inches) that could be a # 4012 bulb. This also depends a bit on how and where you measured the bulb and fixture it goes into. Scroll halfway down the page at this first link to the "Fog & Driving Sealed Beam 6-8 Volt Light Bulbs" section, in the "5 1/2 Inch diameter" category. https://www.taillightking.com/fog_Dr...ight-Bulbs.htm They are a bit pricey on this page but I used it to get the part number, 4012. "A" = Amber colored lens, no letter after the part number would be for a 'clear' lens Another bulb industry size designation for the lamp is "PAR 46" (if the old size is measured correctly) with the "46" being the diameter of the bulb in 1/8th inch units, in case converting mm to inches wasn't already confusing enough. (PAR = parabolic aluminized reflector) You may have different / better internet search results using; 'par 46 fog lamp'. Assuming this a good part number for you... you can search the internet for better prices or sellers closer to you. A couple examples... http://www.classicautobulbs.com/auto...bulb_amber.htm https://www.ebay.com/itm/1940-50-s-C...4AAOSwTO9eUWCR There are similar slightly smaller bulbs, with a different part number, 4015-A (PAR 44) These are also shown in the "4 1/2 inch" 6 volt sealed beam category at the first link above. Example... https://www.chevsofthe40s.com/detail...v_5_Screw.html A bulb and lamp supply store should have better prices on these than specialty and classic car suppliers, if the bulbs are available from their sources. . Last edited by dmsfrr; 01-16-2021 at 07:19 PM. |
01-17-2021, 03:19 AM | #3 |
Measuring that is the problem with the matter. The headlight, where the lamp should go in, has an inner diameter of 144mm at the narrowest point. (Measured with a vernier caliper) My 12V headlight insert that I have here has an outer diameter of 140mm (Absolutely!) This website ... https://www.taillightking.com/fog_Dr...ight-Bulbs.htm ...added to my confusion! One speaks of 5 1/2 inches, and once of 5 3/4 inches. When I look at THIS website ... http://www.classicautobulbs.com/auto...bulb_amber.htm ...then again we are talking about 5 3/4 inches, and the description says diameter 146mm! But I only have 144mm! Is there a tolerance or not? Where are the calculated 2mm that the lamp insert would be too big? All things that do not help to unravel. I didn't know the size designation "PAR 46" before. Thanks for the explanation. Then I can look in that direction too. Another question: "Passing" is written on many lenses. Mine says "Fog". What is the difference between these lamps? Are the fog lamps particularly wide? Greetings from Berlin Andy |
