05-19-2020, 11:48 AM | #1 |
oil level
Engine was at ""L" so I added a quart and it only brought it up about 1/4", less than half way to "F". Started the car and let it run a few minutes and shut it off, let it sit and still 1/4" above "L". Stick is gong in all the way. Doesn't seem right. How much oil should it take to go from "L" to "F"?.
05-19-2020, 01:12 PM | #2 |
Re: oil level
Hi Killer,
You don’t want to drive it full of oil. Quarter is just fine, the higher the oil level, the more chance of it leaking out the rear main. And if you must park on a hill, park nose down if possible, for the same reason. Just my 2 cents.
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
05-19-2020, 01:27 PM | #3 |
Re: oil level
That's a good question. Next time I change my oil, I'm going to check the dipstick after adding each quart to see how much it impacts the level.
05-19-2020, 04:53 PM | #4 |
Re: oil level
The dry engine holds 5 quarts. One quart is in the valve gallery and dipper trays in the pan. I drain out 4 quarts, and add 4 quarts per oil change. My dip stick reads F. I understand there are some differences in dip sticks, not sure why. So drain your oil, and add the 4 quarts back in, and verify/mark that on your dip stick. That’s the correct amount of oil. If your throwing, burning, or leaking oil, then your engine has a problem needing correction.
05-19-2020, 06:53 PM | #5 |
Re: oil level
I believe there were at least two different length dipsticks....if I’m remembering correctly. Might want to check what you have.
05-20-2020, 02:19 PM | #6 |
Re: oil level
05-20-2020, 04:29 PM | #7 |
Re: oil level
They had 3 different oil pans and 2 different dip sticks that I know of so there could be some mis-matching but I can't figure how it could be that different from one to another.
05-21-2020, 09:21 AM | #8 |
Re: oil level
As has been said above, drain and then refill with 4qts. Check the level on your dipstick and mark with a file if not the same as factory mark. From there on you'll know where you're at.
05-21-2020, 09:32 AM | #9 |
Re: oil level
I have seen the finger hole on Oil dip sticks deformed. That could create an incorrect reading of your oil level.
I would drain and refill. Than see if adjusting the finger opening up or down solves your problem. Enjoy. |
05-21-2020, 09:40 AM | #10 |
Re: oil level
One thing about a stock model A---if you over fill the crankcase it will adjust the level itself, and apply rustproofing to itself at the same time in some areas
05-24-2020, 08:02 AM | #11 |
Re: oil level
Did an oil change yesterday. Put in two litres and the oil was on the stick, 3 litres and it was at "L" and 4 litres just below "F". Litres being just a little smaller than US quarts, 4 quarts would be pretty much bang on "F". I initially freaked out when I pulled the plug as it looked like nothing was coming out. It ran out REAL slow for such a big drain hole. I let it drain for a few hours then checked with the dip stick after to make sure that it was clean just in case it was reading oil on the dipper tray and not in the pan. No idea why, when filling it went from "L" to pretty much "F" with one litre but when I was topping it up it before only went from "L" to 1/4 of the way to "F"???. Something still seems goofy I just don't know what.
05-24-2020, 10:21 AM | #12 |
Re: oil level
Always drain oil when hot after a drive.
05-24-2020, 10:33 AM | #13 |
Re: oil level
05-24-2020, 10:38 AM | #14 |
Re: oil level
I typically always do drain when hot. In this case, that wasn't practical. Still should have drained faster than it did IMO though. Yes I did open the filler and pull the dipstick to let it drain faster but it didn't help. Good suggestions though, thanks. i would have made the same comments if I had read that post.
05-24-2020, 10:42 AM | #15 | |
Re: oil level
Was this the first time you drained the oil? Have you had the pan off this engine yet to check for sludge build up?
Dave / Lincoln Nebraska |
05-24-2020, 11:40 AM | #16 |
Re: oil level
05-24-2020, 12:03 PM | #17 | |
Re: oil level
That's jay I thought. I even stuck my finger in the hole to make sure it was clear.
05-24-2020, 08:12 PM | #18 |
Re: oil level
Did you use plastigauge to set the clearances or just by feel?
If by feel you probably need to check them again and use plastigauge to set them. Since you pulled the pan and cleaned it I'm sort of at a loss as to why the oil didn't drain better. 5 quarts in 300 miles is an alarming amount of oil to be loosing. It's got to be going somewhere.
05-24-2020, 08:19 PM | #19 |
Re: oil level
if the drain tube for the rear main was missing I would not be surprised if other things weren't correct (though it could have fallen out). On my old engine the "rebuilder" decided not to use a gasket between the flywheel and block so I always had a puzzling drip coming from there. That amount of oil missing is not right - check the unserside of the car if you have not already.
"The more things change, the more they stay the same." |
05-25-2020, 08:59 AM | #20 | |
Re: oil level
