11-22-2020, 06:25 AM | #1 |
U joint rebuild
Help, installed new bushings in u joint and now need to install c clips . Any tricks to getting theses things in??? 1930 pickup thanks
11-22-2020, 09:09 AM | #2 |
Re: U joint rebuild
Can you post a pic of the ujoint you are working on, that will help.
11-22-2020, 10:25 AM | #3 |
Re: U joint rebuild
On the early Ford type U-joint, just make sure the C-ring grooves align with the slots in the yokes. The C-rings can then be pressed into the grooves.
https://modelagarage.com/service_let...iversal-joint/ |
11-22-2020, 11:54 AM | #4 |
Re: U joint rebuild
wrong post sorry.
11-22-2020, 02:10 PM | #5 |
Re: U joint rebuild
