06-18-2022, 06:43 AM | #1 |
Distributor
My question today is I pulled the Distributor off of my ‘30 Tudor. It came out tough she was stuck. When it finally eased out I noticed the second half of the shaft stayed in the motor. I installed all the new components and realigned the shafts and put things back together. Looking back I’m worried now that even though everything lined up and went together nicely can that shaft give me trouble seeing it had separated like it did? I’d like to pull it and replace it before starting the motor if need be.
06-18-2022, 09:29 AM | #2 |
Re: Distributor
Hi Lenny, is it the lower shaft that goes down into the valve gallery you're talking about? if so, I wouldn't worry about it too much. my lower shaft stays in the engine when i pull the distributer
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!" |
06-18-2022, 09:35 AM | #3 |
Re: Distributor
It’s the longer part of the shaft connected to the distributor. It separates from the upper half when I removed the distributor. It lined back up when I reinstalled it. All videos I’ve seen the whole unit comes out as one.
06-18-2022, 09:51 AM | #4 |
Re: Distributor
No problem. You have a separate lower shaft. Mine does too ---- as long as the engine is driving the distributor and the distributor is fully seated against the head and secured with the locking bolt, you're fine.
06-18-2022, 09:52 AM | #5 |
Re: Distributor
Phew that’s a relief! Thanks a million!
06-18-2022, 01:11 PM | #6 |
Re: Distributor
06-18-2022, 01:32 PM | #7 |
Re: Distributor
I agree with Bob, no biggie just hook it up and ride off into the sunset
06-18-2022, 07:08 PM | #8 |
Re: Distributor
Thanks I will do just that!
06-18-2022, 07:40 PM | #9 |
Re: Distributor
no problem mate, keep the questions a-coming. love answerin' em.
06-18-2022, 09:19 PM | #10 |
Re: Distributor
Your A was designed with the two-piece shaft. The one piece is an aftermarket item. The split is to allow some flex in the shaft. Two is supposedly better.
Brian SATX |
06-19-2022, 07:27 AM | #11 |
Re: Distributor
You guys are the best!! I’m learning so much and loving every minute of it!! Can’t thank you all enough! LOVE this forum!!!
06-19-2022, 07:32 AM | #12 |
Re: Distributor
Your welcome mate, that is what the forums are all about. getting cars on the road and talking about all things blue oval.
06-19-2022, 09:13 AM | #13 | |
Re: Distributor
Terry |
06-19-2022, 10:27 AM | #14 | |
Re: Distributor
Better to use a small amount of anti-seize grease that conducts electricity.
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 06-19-2022 at 10:42 AM. |
06-19-2022, 03:51 PM | #15 |
Re: Distributor
And don't forget the small piece of thin leather put in the "slot" before going together.
Kidding - the leather was an "aftermarket fix" aimed at addressing any developed "slop" between components. New parts go together "closely" and don't require any leather/paper or other "filler." (And this the reason it is best to replace all - possibly including the oil pump drive.) Why would anyone sell a "used" vertical shaft gear on Ebay? Maybe for some slop is a way of life? Slop is not fatal but it can present challenges in timing the engine. Joe K
Shudda kept the horse. |
06-19-2022, 05:43 PM | #16 | |
Re: Distributor
Terry |
06-19-2022, 06:47 PM | #17 |
Re: Distributor
I've got a 100% solution. Pull the distributor out once a year and wipe down the shaft with engine oil.
Dave / Lincoln Nebraska |
06-19-2022, 07:23 PM | #18 |
Re: Distributor
I have looked but never found upper and lower dist shafts fabricated out of stainless steel. And yet everyone has a rust problem with these shafts. Stainless seems like the obvious long-term fix
06-19-2022, 08:05 PM | #19 |
Re: Distributor
Might still wear the driver, tool steel might be an alternative, but nothing lasts forever.
06-19-2022, 08:21 PM | #20 |
Re: Distributor
While stainless steel might sound like an attractive option, it is generally soft and so wears more. The stainless water pump shafts don't last as long as the original, good quality steel did but they look pretty.
