My 31 Tudor engine had a squealing noise that I could not locate. The plan was to attack each point in order and check possible success.
1. Oil distributor shaft 2. Oil engine front mount 3. Spray water on fan belt 4. Remove fan belt to exclude water pump and alternator as the source. 5. Scratch head (mine!) 6. Sign on to Ford Barn for new ideas. #1 solved the problem and no additional action was needed. It is great when an easy fix shows up!! |
